August 05, 2025, 08:02:16 PM *
Author Topic: boot lock vandal.....  (Read 5166 times)
2door350
RAT 059
« on: October 10, 2009, 06:57:40 PM »
Someone has tried to get into my boot and jammed the lock up so now my keywont go in Angry....how do i get it open from the inside?s it easy?
ben
Rusty_T
« Reply #1 on: October 10, 2009, 07:52:29 PM »
 Tongue
Ben,
I think the lock is held in place similar to the door locks. If you can access the inside of the boot from inside the car, then you should be able to remove the plate that holds the lock in place. Then get out of the car, remove the lock, and you should be able to open the boot with a flat screw driver the same way as the lock would have. Clear as. It should work.
Cheers Rusty
« Reply #2 on: October 10, 2009, 10:45:28 PM »
Much easier is to undo the 2 x 7'16 head bolts which hold the lower catch in place. If you use 3 or 4 long extensions, you don't even need to crawl into the boot area.
2door350
RAT 059
« Reply #3 on: October 12, 2009, 05:38:07 PM »
thanks for the suggestions, i'll give it a go....
surferboy
10,000 POINTS !
« Reply #4 on: October 12, 2009, 11:46:14 PM »
Hey Ben
It can't be hard 'cos EVEN I managed to fix mine when it got jammed.
Pulled the back of the seat out, crawled in the boot, unbolted the lock, opened the boot
AND......shock and suprise
put it all back together and it works  Grin
 Cool Cool Cool
cruisin's great with a 58
Paul In Ireland
« Reply #5 on: October 13, 2009, 05:18:08 AM »
Of course, if all else fails, just cut a hole in the boot lid about the size of a fist and then just reach in and open! Sorted!  Grin
jack_fc
SouthWest Coast, Victoria
« Reply #6 on: October 13, 2009, 09:21:39 AM »
A perfect example of Irish Logic....
Paul, maybe you've been over there a little too long?  ;
Isn't it about time you went home?    Wink Wink Wink
