May 28, 2025, 03:56:11 AM *
Author Topic: What springs for SBC and HR front end  (Read 3014 times)
earlyholdenfan
« on: September 24, 2009, 04:28:17 PM »
Hi all, just wondering what springs I should run with a SBC and a HR front end, will the standard height ones compress too far under the additional weight? is there a heavy duty set I should order? what is everyone else running, also same for shocks, anyone have recommendations?
Matt
« Reply #1 on: September 24, 2009, 04:54:18 PM »
Matt,
I ran 1.5 inch lowered Heavy Duty springs by KMAC with HR drum brake stubs, sat pretty low with a 308... but I like them low.  Could run 185/65x14 with no scrub.
fcv85l
« Reply #2 on: September 24, 2009, 09:20:39 PM »
i fitted standard height lovells springs in my fc with sbc and it sits ok,if i can get enough guard clearance with p76 rotors i will drop it an inch
earlyholdenfan
« Reply #3 on: September 25, 2009, 09:15:21 AM »
Thanks guys I will probably get a set of std height H/duty ones - can always change them later on if I want it lower.
anyone have any ideas on shock absorbers?
Matt
« Reply #4 on: September 25, 2009, 11:32:06 AM »
Any HR shocks will work, they all dampen the rebound of the spring.
The quality of the shock and the amount you spend is your choice but any will work.
« Reply #5 on: September 25, 2009, 12:26:18 PM »
Koni make a nice double acting adjustable shock for HR front end only down side is to adjust it you have to unbolt the bottom full extend it and then rotate to adjust ........FC427.......
