May 28, 2025, 04:11:43 AM *
Author Topic: Sump  (Read 12815 times)
jasonr70002
« on: September 07, 2009, 02:29:05 PM »
Hey guys does it have to be an EH sump for the red motor conversion or is there another on also like LC torrie etc.
Golden Holdens FE-FC
Ol_Girl_58
getting there...
« Reply #1 on: September 07, 2009, 02:50:05 PM »
There was some discussion about this at an earlier date, although I am unsure which thread. It had pictures too.
IIRC, in an FC, a LC/LJ sump combined with a HR front end will cause the engine to sit a couple of centimetres closer to the firewall when compared to an EH sump combined with HR front end.
I am happy to be corrected though  Smiley
Kind regards,
Ol_Girl_58
colt
« Reply #2 on: September 07, 2009, 05:43:38 PM »
I was told over the weekend of an EK with red, HR front end and HK,T,G sump. The 'bell' of the sump sits between the crossmember and the drag link.
I'm sure this option would have been tried before.
Colin.
colt
jasonr70002
« Reply #3 on: September 07, 2009, 05:45:35 PM »
Cool sounds good fellas it opens my options a fair bit more. Does a HQ sump work also being a rear hump.
« Reply #4 on: September 07, 2009, 07:32:28 PM »
I don't believe a HKTG sump will fit an FC nor will a HQ. Early Torana and EH are the only 2 which will fit without modification.
jasonr70002
« Reply #5 on: September 07, 2009, 09:27:57 PM »
With the price that people want for EH sumps it might be cheaper to modify one
ratbox
« Reply #6 on: September 08, 2009, 04:32:09 PM »
i had an FB van with a H/KTG sump fitted so it can be done, i didn't do it it was like it when i bought it so not real sure how it was done but the mounts were at the back of the cross member as usuall
Geoff_K
The 2 BAY s
« Reply #7 on: September 08, 2009, 05:31:44 PM »
In the 1970's I modified/merged an EH Sump and a HR sump.
Ended up with 2 sump plugs, and plenty of oil capacity
I fitted the HR Disc Brake Front End and Drag Link at the same time as I fitted the 202 Red Motor.
All you need is 2 sumps, and some modification to oil pickup.
Geoff_K
jasonr70002
« Reply #8 on: September 08, 2009, 07:23:37 PM »
Geoff is the drag link off a HR as well and how did you make the sump ?
vintageholden
« Reply #9 on: September 08, 2009, 08:54:03 PM »
how did you make the sump HuhHuh?
grinder and a mig...........
jasonr70002
« Reply #10 on: September 08, 2009, 09:25:04 PM »
Lol nice one I meant what went where and the measurements etc.
vintageholden
« Reply #11 on: September 09, 2009, 02:27:32 AM »
sorry
trial and error........
cut the hump off and weld it at the rear...
hard to explane over the net....
vmx-mxr
« Reply #12 on: September 09, 2009, 07:37:14 AM »
This thread begs the question.
For a gumby (me) how do you distinguish an en EH or early Torana sump from all the rest. The van I am buying has already had a red conversion done which looks OK (it's a 179 so perhaps it was an EH engine anyway) but it does seem like the engine sits pretty close to the front. The pump mounted fan has been eliminated in favour of an electric - forward mounted - one.
Is there an easy way to pick one?
Dave Mac
« Reply #13 on: September 09, 2009, 08:07:25 AM »
The sump "hump" is at the back of the motor.
Geoff_K
The 2 BAY s
« Reply #14 on: September 09, 2009, 09:23:44 AM »
For Jason,
The drag link is HR (in fact complete HR disc brake front end, steering arms, links etc) up to FE Steering Box spline.
Cutting the sumps - long time ago, I think I used a hacksaw, would use a nibbling tool if I were to do it today.
Welded/braised it all back together with the oxy. (3 to 4 pieces were rearranged/needed - from 2 sumps)
In the process I set the Red Motor lower than standard, so the Toyota 5 speed was fitted without cutting out the floor.
Not the most elegant job, but it works. (car will be at 13th Nats if you want to have a bo-peep)
Geoff
CraigA
« Reply #15 on: September 09, 2009, 09:35:49 AM »
Here's a really good resource regards sump profiles/types
http://holdenpaedia.oldholden.com/Sumps
FB_MAD
« Reply #16 on: September 09, 2009, 09:44:53 AM »
Dave Mac
 Roll Eyes Dave , an EH sump is very near the same profile as a grey motor sump but approx 1 inch longer.
LC/LJ Torana sumps have the sump hump right at the rear of the sump assembly, if that makes any sense.
Other red motor sumps are a combination of in betweens for hump position.
Has anybody seen my red pen??
vmx-mxr
« Reply #17 on: September 09, 2009, 10:31:47 AM »
As always - thanks guys.
That link posted by Craig was very good and the other tips useful too - now which one is regarded as the best one to opt for. I like the idea of the baffle to reduce surge in the Torana sump.
It'll  be interesting to look at the sump on the van when I see it again.
Dave Mac
FB_MAD
« Reply #18 on: September 09, 2009, 01:14:22 PM »
Unless you plan on racing around a track or rallying a bit the baffle really won't make a difference on a normally driven road car.
Go either way but I'd go for the EH sump personally.Make sure you get the oil pickup to suit the particular sump you choose.
jasonr70002
« Reply #19 on: September 09, 2009, 04:08:43 PM »
What is a bolt in collapsible column to fit as well
Page created in 0.207 seconds with 20 queries.
