August 09, 2025, 12:13:55 AM *
Author Topic: diff mounting brackets  (Read 2500 times)
fc_ute
« on: January 14, 2003, 02:23:42 PM »
need to fit a standard diff back into a ek but i am missing the mounts that bolt to the diff and the shockies(what the u bolts go thru)and also the rubbers and metal retainers.
i think fe/fc should be the same
would prefer someone in WA so i can pick them up
craig  0419949987
fcfromscratch
FC - Fantastic Cars
« Reply #1 on: January 14, 2003, 02:40:26 PM »
Craig,
I have what you want.  I took standard stuff off my FC to fit the HR axle (which has integral brackets of different shape) so my u-bolt/shockie mounting plates and assoc hardware are going begging.  The rubbers are not in very good condition though.  They can be yours for the trouble of driving all the way to Rockingham...
regards....Brad
air-chief
« Reply #2 on: January 15, 2003, 06:03:23 AM »
Hey fc_ute
FB&EK have a rear spring that is slightly wider than the FE&FC. You might find it hard to use the metal retainers & rubber mounts from an FC
a-c
« Last Edit: January 15, 2003, 06:05:57 AM by air-chief » Logged
fc_ute
« Reply #3 on: January 15, 2003, 02:52:30 PM »
thanks brad, once i get motorvation out of the way i will come down and see you
craig
and thanks for the tip air-chief
