August 24, 2025, 01:02:23 PM *
Author Topic: External Oil Filter  (Read 4343 times)
utey
« on: July 25, 2009, 11:27:26 AM »
Hello
Are there any negatives to fitting EOF ?
I have the housing and the bracket, what fittings do I need? (pictures would be handy)
Braided hoses or copper pipe?
Any help appreciated.
Nick
« Reply #1 on: July 25, 2009, 12:52:19 PM »
Steel  lines would be OK  Copper work hardens and will eventually fail ... or cheaper than braided hose would be use SAE 100 high pressure  hose.......FC427.......
« Reply #2 on: July 25, 2009, 05:41:52 PM »
To answer the original question, no there aren't really any negatives, but precious few positives either.
It's a bypass system, which means you might get 5% of your oil through it. There are a few more fittings to leak and/or fail, and a not-easy-to-come-by filter. Sounds great when you put it that way.
A few blokes have modified them to produce full-flow filtration. That might be useful, but as a general rule in stock form they're hardly worth the bother. IMHO. YMMV.
Fc1958
« Reply #3 on: July 25, 2009, 07:19:30 PM »
and why wouldn't you want the potato cooker look Smiley
“Old Holdens never die… they just go faster!”
« Reply #4 on: July 26, 2009, 06:02:14 PM »
Errm, that's an oil-bath air filter. The OP was asking about oil-filters:
utey
« Reply #5 on: July 29, 2009, 05:02:40 PM »
Thanks for the comments , don't think I'll bother.
Just ensure I change the oil a little more regularly.
Nick
Page created in 0.02 seconds with 19 queries.
