September 08, 2025, 05:33:06 AM *
Author Topic: Sand Blasting  (Read 4915 times)
Not Happy Jan
Aussie adventure
« on: July 24, 2009, 08:11:21 PM »
Just testing the waters because I have never done this before Tongue Undecided .... has anyone tried to do this themselves. Someone gave me a kit from bunnings and i thought that i would try it out on the backs of the guards and the front end to clean them up. I have a good strong compressor so that is not an issue.
I know I'll have to screen pretty well...
But how much and what sort of sand does it use  Huh
Nick
You can never have too many!
Port Macquarie NSW
« Reply #1 on: July 24, 2009, 08:55:46 PM »
Don't use sand as it gives of gas which is poisonous...I think the disease is call silicosis ,you get from breathing the gas that is released from sand when it hits an object under pressure as in blasting ...There are many different mediums that can be used safely Garnet ,Glass, soda , Wallnut shell , plastic etc etc  I think unless your compressor is around 20CFM that doing more than a small area at home is out of the question ,Garnett comes in quiet a few grades and is your best bet and at around $25 a bag the most affordable .....FC427.....
TTV6FC
« Reply #2 on: July 24, 2009, 09:06:09 PM »
Be carefull not to blast big flat panels as they are easily distorted by the pressure/heating effect of the sand on the steel.The guy who does my sandblasting says any panel that you can easily push in (flat part of bonnet etc) should not be blasted.
Not Happy Jan
Aussie adventure
« Reply #3 on: July 24, 2009, 10:37:11 PM »
OK thanks.... so mainly back to elbow grease.
2 questions then
How do you get the  black stuff off the insides of the panels?
Where do you get walnut grit and will it work with the gun from bunnings ie what nozzle size suits walnut grit?
Cost effectiveness. Presumeably that i screen how much would i need to order to do the two front guards edges, apron, backs of bumpers, grill surround and two doors??. I would paintstrip the flat bits and sand them off.
Port Macquarie NSW
« Reply #4 on: July 25, 2009, 10:06:44 AM »
The Bunnings guns are very low volume gun I am using one in my blasting cabinet at the moment would take a long time to do what you want I only do small bits at home and send the rest out as it is not cost effective ,difficult to reclaim media , and puts dust and grit everywhere , sounds like you only have about $100 to $150 worth or blasting ......Just my opinion ........FC427.......
Not Happy Jan
Aussie adventure
« Reply #5 on: July 30, 2009, 09:19:52 PM »
I think that getting them done professioanlly is a much better option. Thanks All Grin
Port Macquarie NSW
