August 24, 2025, 06:29:01 AM *
Author Topic: Manifold clean up  (Read 6612 times)
crossply
Paul Reyntjes
« on: July 05, 2009, 05:39:14 PM »
I've got an old alloy Lanspeed manifold that i want to clean up and use.
I'd like to look at either polishing it up or having it painted or coated.
Can anyone give me some feedback on which would be the best way to go with it so it will look good but still be easy to maintain?
Thanks,
Paul
CraigA
« Reply #1 on: July 05, 2009, 05:59:29 PM »
Sandblast then use a clear lacquer like this http://www.ppc.au.com/topcoat_glistenpc.htm
GMB-58FC
Stage one complete...
« Reply #2 on: July 05, 2009, 06:00:29 PM »
Thanks,
Paul
Paul, unless you really want the polished finished id look at getting it coated rather than painted.  I can run through what to do if you want to polish it by hand or you can get it blasted.
Cheers Ben
ABS Hobart- 6231 5855
PM FOR QUOTE
fcv85l
« Reply #3 on: July 05, 2009, 06:01:42 PM »
polishing is fine if it is a good casting but continual polishing will be necessary to maintain its look alternatively 2pac or powdercoating would look great and less maintainance
crossply
Paul Reyntjes
« Reply #4 on: July 05, 2009, 06:25:32 PM »
Sandblasting sounds like a good idea, i hadn't thought of that. What sort of finish do you end up with after blasting?
GMB-58FC
« Reply #5 on: July 05, 2009, 06:32:44 PM »
It depends on what they blast it with but it will be a rougher finish that will need to be cleaned up by hand if your to polish/coat it but nothing major.
PM FOR QUOTE
CraigA
« Reply #6 on: July 05, 2009, 06:36:42 PM »
Sandblasting (or preferably glass beading) is the answer. It will give you an as new factory type finish - the Glisten product will maintain the look over time.
If you want a polished look then sandblasting isn't the right choice.
crossply
Paul Reyntjes
« Reply #7 on: July 05, 2009, 07:02:41 PM »
Thanks for the advice Guys,
Does anyone know what it would be worth to have it polished? i like the idea of getting it polished up and then coating it for protection.
If not, I might blast it and and see how it looks.
Paul
GMB-58FC
« Reply #8 on: July 05, 2009, 07:20:01 PM »
Paul
Polishing it generally not cheap as there is a fair bit of time involved and labour intensive.  Its not all that hard though so you should have a crack at it yourself.
PM FOR QUOTE
crossply
Paul Reyntjes
« Reply #9 on: July 05, 2009, 07:28:36 PM »
Yeah, i'm keen to give it a go myself.
Any tips on what to use and how to go about it for best results?
Paul
« Reply #10 on: July 05, 2009, 08:31:03 PM »
Paul, I use a place in Coreen Ave Penrith, they polish a lot of bike stuff & are reasonable, about $50 for a rocker cover from memory
In the past I have used a product, (don't think it was the stuff Craig reccommended), but I had a bad result & had to strip & re polish the bits, but I was using the brush on directions.
I find that they hold their lustre well, just give them a go over with Purple Polish now & then.
Gary
« Reply #11 on: July 06, 2009, 08:42:55 AM »
Polishing is a filthy business and can take a lot of time depending on the piece. There are polishing kits available from places like Bunnings, but you need to get a smooth surface before polishing, it's a gradual process of using finer sandpapers down to about 800 grit, then polishing from there. If you can get a pro to do it for a reasoinable cost go for it.
I used the POR resto kit with a brush on clear coat and my polished stuff still looks good, I even did the cast finish on my alternator to make it easier to clean.
GMB-58FC
« Reply #12 on: July 06, 2009, 09:10:14 PM »
Are there any casting marks on the manifold and is painted already???
PM FOR QUOTE
