September 06, 2025, 10:06:46 PM *
Author Topic: Can a magneto fit a grey  (Read 5482 times)
barryjones
« on: June 20, 2009, 09:03:54 PM »
Gday
Just a quick question, can these magneto's fit a grey motor?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MESELX:IT&item=200354433123 anyone have any pics of one fitted?
« Reply #1 on: June 20, 2009, 09:21:19 PM »
Looks like a vintage car magneto in the add ... we run a Vertex Magneto in the mates FED,[ RED ENGINE ] have seen them also fitted to Grey's but a long time back  will look through the old Drag Racing News for a picture of one Huh Hardimans  Performance are still the agent for Vertex and should be able to help you out if you want to go down that path ........FC427.......
CraigA
« Reply #2 on: June 20, 2009, 09:31:55 PM »
The grey powered speedway midgets mostly ran magnetos.
Not sure what type though, but I'm sure Alex would have a picture of one in his amazing photo archives.
« Reply #3 on: June 20, 2009, 09:55:43 PM »
Magnetos were available for Holden Industrial Engines.
Made by Scintilla Part Number 7414491
ACE  Cool
barryjones
« Reply #4 on: June 21, 2009, 10:20:13 AM »
Thanks for the quick responses, will look into it a bit further.
Dave88
« Reply #5 on: June 21, 2009, 05:46:27 PM »
Hi Barry,
Yes that Judson electronic magneto will work in conjunction with a grey motor. From what I've researched, production of these units began in the late 50's through to the late 60's. The Judson unit is basically a capacitor that steps up the primary voltage, which in turn, gives your existing coil a hotter output. They're used in conjunction with an existing ignition system (ie. a standard grey motor distributor and coil)
Apparently a 6 volt and 12 volt version were produced, but I've only ever seen the 6 volt model.
The Judson unit is not related to the internal coil/self sufficient Vertex type systems that most people think of when they hear the word magneto.
I have a fitting/instruction manual here for the Judson unit that I can photocopy if you need
« Reply #6 on: June 22, 2009, 07:38:13 PM »
This is the best I could do.
« Reply #7 on: June 22, 2009, 07:40:11 PM »
Alex that looks like a Vertex ......FC427......
