August 24, 2025, 06:25:30 AM *
Author Topic: generator & regulator  (Read 4534 times)
philby26
« on: June 09, 2009, 08:29:11 PM »
Hi guys
just a question on the grey motor generator & regulator
are they a matching item or not ? my brothers car(fc) had problems so he took the generator to an auto sparky
and they are telling him he needs to put an alternator in, as the generator & regulator  are a set pair "i thought it was rubbish"
so i thought i would ask you guys
so a bit of advice would be greatfull
cheers Phil
mc54
« Reply #1 on: June 10, 2009, 04:16:20 AM »
I have a ACDelco regulator in my vehicle with a Bosch generator. Everything works fine.
Mike
CraigA
« Reply #2 on: June 10, 2009, 09:23:28 AM »
I am guessing that he is referring to the fact that the regulator is set up to suit the generator.
If you change the generator you would need to recheck regulator settings - and vice a versa.
Just put an alternator on and chuck them both away  Wink
« Reply #3 on: June 10, 2009, 11:08:18 AM »
I remember when fitting a new regulator for a generator that the Auto Electrician had to Polerise it to suit if it was a + or - earth car or was that only pommy cars  Huh Huh Huh Huh  must be having a senior's moment ......FC427....
« Reply #4 on: June 10, 2009, 11:22:34 AM »
FC 427
I once had a Ford Prefect that was converted to 12 volt, the issue with most Pommy cars is that they were positive earth and not neg earth.
I had the Prefect "polarised" so that i could fit niceties like a radio etc
« Reply #5 on: June 10, 2009, 06:10:29 PM »
Generally you should use a Bosch regulator with a Bosch generator and a Lucas regulator with a Lucas generator etc.  They are not matched as a pair.  Sometimes you can get away with mixing them but voltage and current outputs will not be optimum. The worst case scenario with a mixed set is that the battery overcharges continually. On the other hand, undercharging will result in shortened battery life.
philby26
« Reply #6 on: June 10, 2009, 10:29:00 PM »
Thanks guys
I will look into it then and see what we come up with.
cheers Phil
fcv85l
« Reply #7 on: July 05, 2009, 08:37:30 PM »
mcl1959 is right
