August 05, 2025, 03:31:56 PM *
Pages: 1 ... 10 11 [12] 13 14 ... 60   Go Down
Author Topic: 365 weeks...  (Read 872909 times)
« Reply #220 on: December 06, 2010, 01:12:21 PM »
Another few moments on the ute. Made a couple of bracket for the fuel filter and the vapour seperator (well I think that's it).
Does anyone know where to get some of this fuel line in Melbourne as well. Need a little more length than what I have. (Lots of lines there!)
Some rear wiring harness next hopefully.
Thanks JB
« Reply #221 on: December 06, 2010, 02:25:42 PM »
Thinking about it I will use a rubber hose and some clamps on the old fittings.
Should make it a little easier to find and make the appropriate length.
brett_f
« Reply #222 on: December 06, 2010, 05:40:37 PM »
JB.
Rubber fuel lines can normally be bought at the speed shops in length. Some of the connections on your tank may go to the carbon canister and throttle body. I ran metal pipes to the front of the vehicle for this only to be told by the engineer i did not need to run the canister due to the year of the vehicle and some other things. Check with your engineer first as you may not have to run additional lines/hoses.
regards Brett
« Reply #223 on: December 06, 2010, 05:56:28 PM »
use a stubby holder around your fuel pump or small resilant mounts tp keep the noise down them 044,s are noisy buggers.
« Reply #224 on: December 06, 2010, 06:16:27 PM »
Thanks Brett, the lines I am running are directly from the commodore, 3 in total, feed return and vapour, plus  the brake line... All i did last time was carefully straighten the old ones out and rebend them. I have a flare kit to re do them when I cut the lines to go through the floor near where the tank is and the fuel filter.
Pete, thats a steel fuel filter, the fuel pump is the one from the VT which is contained in the surge pot inside the tank. I will show you a photo. So from memory I think I could just hear it in the van... sometimes not as the stereo was usually up a bit  Grin Grin
« Last Edit: December 06, 2010, 07:30:03 PM by fevanv6 » Logged
« Reply #225 on: December 06, 2010, 07:31:44 PM »
Should have looked a bit harder shouldnt i
Thats how big my day was at work was looking at the forum on my phone bit hard to see pics.
Looking good.
« Reply #226 on: December 06, 2010, 07:31:48 PM »
The photo of the fuel pump and surge tank.
« Reply #227 on: December 09, 2010, 05:30:56 PM »
Ever got to a stage when you look and think where do I go here  Huh Huh
Some of the wires have to be lengthened, some shortened and some the same. Big time brain teaser!!
brett_f
« Reply #228 on: December 09, 2010, 09:02:31 PM »
JB,
I know what your going through. i did the same. Easiest way is to remove all the tape and run the wires to the areas you know. Shorten and lengthen and then work on the others last. its all worth it in the end mate
Brett
« Reply #229 on: December 09, 2010, 09:15:38 PM »
Thanks Brett,
I have 2 front wiring harnesses so am planning on joining the two to get he correct length and have the same colour codes with all of the relays etc behind the seats.
Trouble I am having at the moment is where to join the 2. Lots more thought to go into it before I get into it with the snips  Grin Grin
« Reply #230 on: December 12, 2010, 08:35:25 PM »
Couple more shots of some slow progress this week...
Fuel system hooked up to the tank, have to get some more fuel line to run to the front of the car as the donor stuff rusted. But happy with the result at the back.
Many hours spent on cleaning up the rear wiring harness from the VT donor, removed the back door looms, wired up the rear lights, and the ABS and the fuel pump. But still very messy in here.
Just sat in the lighting switches in the glove box... need to finish off the brackets to make it a little more permanent.
Hope you are enjoying the snaps.
Old_Mt_Isa_Boy
My Ute
« Reply #231 on: December 12, 2010, 09:14:00 PM »
Great Snaps. Those wires do look like spaghetti. Some nice stuff with the fuel tank and tray.
Wayne
TTV6FC
« Reply #232 on: December 14, 2010, 07:05:46 PM »
Lovin it,lovin it.... Cool
« Reply #233 on: December 14, 2010, 09:55:35 PM »
Keep going, your entertaining me.
« Reply #234 on: December 16, 2010, 05:39:05 PM »
Not much to show for a days work, couple of holes, a mess of wires on the floor of the garage... and a some neatened connectors waiting for the front wiring harness. At least the rear section of the wiring is nearly done.
« Reply #235 on: December 17, 2010, 08:15:13 AM »
looks like fun JB
« Reply #236 on: December 17, 2010, 09:24:45 AM »
8 years since the last time I did this Ed, I had forgotten how much "fun" it was... 2 bruises on the rib cage and a sore neck from lying on the tray manipulating the soldering iron and hair dryer for the heat shrink, I am a bit sore this morning.  Grin
« Reply #237 on: December 17, 2010, 01:31:47 PM »
8 years older, 8 times sorer i bet  ha ha
« Reply #238 on: January 08, 2011, 04:53:05 PM »
Been sitting in cramped places for 10 hours now, more sore neck and lower back... stuff all to show for it really.
The rear harness has been completed. Started on the main harness last night and continued today.
Bloody hard to know where to start, walked away a couple of times before I cut too many wires in frustration. All the brackets have been made for the relays, and fuses and am hoping that when i get this bit tidied up that it will get a bit easier to extend the connectors to the correct places. Hopefully the next shot will be a tidy wiring set up in the back.  Undecided Undecided Grin
« Last Edit: January 11, 2011, 08:20:45 PM by fevanv6 » Logged
pedro
« Reply #239 on: January 08, 2011, 05:20:43 PM »
Looking good JB, you've certainly made some progress since i last checked, have fun with the spagetti Wink
              Pedro
Pages: 1 ... 10 11 [12] 13 14 ... 60   Go Up
Page created in 0.044 seconds with 16 queries.
