August 02, 2025, 07:16:51 PM *
Pages: 1 [2] 3 4 ... 60   Go Down
Author Topic: 365 weeks...  (Read 871252 times)
TTV6FC
« Reply #20 on: May 06, 2009, 07:18:16 PM »
Awesome work Jason,lot's of skills on show here. Shocked
ofc304
« Reply #21 on: May 08, 2009, 07:37:46 PM »
great to see a big task  Shocked i've been panel beater painter for near 30 years thats a BIG job great to see it in the flesh keep it up good show Shocked Shocked
« Reply #22 on: May 09, 2009, 04:06:38 PM »
Now to make these fit where they should... 18x10's
This is the plan...
FATBOY
« Reply #23 on: May 09, 2009, 05:31:45 PM »
im getting excited all ready jason still got your tailgate but me mate isnt driving anymore
regards fatboy
fatboy
0414712441
« Reply #24 on: May 10, 2009, 08:24:38 PM »
Some toying around....
Just an 18' rim turned around for the effect. The rotisserie makes it real easy to adjust the ride height Grin
tuffute
« Reply #25 on: May 10, 2009, 09:13:31 PM »
Just as well Jason as u have put the wheel on backwards  Cry
« Reply #26 on: May 10, 2009, 09:43:54 PM »
Hey Brad,
Can you take a photo of the Colt hinges you used on the hard cover you made for me please.
When I get the others made I promise to put them on the correct way.  Grin
Jason.
« Reply #27 on: May 11, 2009, 09:16:25 AM »
Cool! Reversed rims making a comeback.
Had an old beddy van with a short diff and reversed rims on the rear.. looked fat.
GOA350
« Reply #28 on: May 11, 2009, 10:58:25 AM »
At this rate Jase you won't be needing my ute for the Nationals Grin Grin
pedro
« Reply #29 on: May 11, 2009, 12:48:58 PM »
Great bit of engineering work there Jason, absolutely fascinating, keep the pics coming.
        Pedro
« Reply #30 on: May 19, 2009, 06:21:25 PM »
Sp apparently you start with a flat piece of 3mm sheet steel, and cut some patterns out... How it was done in the book.
The first one i tried to cut with an oxy template machine.. (not sure what it is called) but the steel was too thin and warped the end result.
So got a piece of 50 x 50 to help brace it while I welded the top and bottom on.
« Reply #31 on: May 19, 2009, 06:24:25 PM »
With both sides done. time to make more holes in the car.
Then a trial fitment before welding in the new rail
« Reply #32 on: May 19, 2009, 06:27:43 PM »
After the completion of one side...
Should be able to get some decent hoops in here.
« Reply #33 on: May 19, 2009, 06:31:31 PM »
Then a present for me when I arrived home after 2 days on the car... I like presents!!
Hopefully some more shots on Friday or Saturday night.
Jason.
« Reply #34 on: May 22, 2009, 06:45:54 PM »
Bit more progress...
Both rails done.
Engine waiting patiently.
Tomorrow... fuel tank.
« Reply #35 on: May 22, 2009, 07:32:08 PM »
Jason.
That is an awesome looking front end. I noticed that there is a decal with V6 Conversions on it, who supplied the front end?
« Reply #36 on: May 22, 2009, 07:57:51 PM »
Hey Keith,
You noticed correctly... Its a V6conversions one. Not much change out of 5K but hopefully will be worth it. It uses all of the Vt commodore stuff that I have, so will save $1000 on a brake conversion, and will be able to put ABS on it. It is a rear mounted power rack and pinion, with coil overs that are fully adjustable.
Pat also stated that he has run 18x8's on the front, but I will be using 17x7's
Chers
Jason.
« Reply #37 on: May 23, 2009, 08:00:59 PM »
341 Days...
The shed dog... One for Kathi.
Fuel tank today, 80 litre VN tank.
The tank has been cut open and 13cm added for 40 more litres, and the VT fuel pump and surge tank incorporated into the tank while open.
TTV6FC
« Reply #38 on: May 23, 2009, 10:49:11 PM »
Top job Jason,that tank sure won't fall out in a hurry... Shocked
« Reply #39 on: May 24, 2009, 11:51:58 AM »
Thanks,
The main reason for the size of the steel was that I wanted to lower it by 40mm from the rails and this was the simplest way. And this was lying around the shed already bent up.  Grin
Pages: 1 [2] 3 4 ... 60   Go Up
