August 30, 2025, 08:28:34 AM *
Pages: 1 ... 55 56 [57] 58 59 60   Go Down
Author Topic: 365 weeks...  (Read 903909 times)
« Reply #1120 on: January 09, 2016, 07:23:06 PM »
So no-one noticed the subtle name change then lol...
Couple of days work just before the weekend, with some rubbers fro the tailgate installed and the floor for the tray finally done.
Got a sheet of 19mm marine ply with a AA finish and cut to shape then using a router to adjust for depth. Pretty happy with the result.
Fixed some wiring issues with the Air Cond, blower fan and the stereo, and nearly got the ABS working. Replaced the ABS module again after the previous 3 from the wreckers were faulty and got the code that I had been waiting for.
Code 28- Wheel Speed Sensor Frequency Error.
Initially I thought it was going to be there from the larger rear tyres giving me 23mm difference in height, but then started looking at it a bit deeper realised that I need to make a sensor ring that will send the correct information as the VT independent rear end had large sensor rings and the VS diff that I am using the rings are contained in the diff so are a lot smaller.
So here is the problem for anyone to have a crack at...
1. I need to work out the amount of pulses sent per km for the VT sensor ring with wheels measuring 235/45/17 (the largest standard commodore wheel size)
2. The amount of teeth on the VT sensor ring
3. Convert this to what I know with the VS diff which is my tyre size 285/40/17 (32 teeth x 482.43 rotations per km =15437 pulses sent/km) Front tyres are 205/50/17
4. Get 2 new sensor rings made and pressed onto the axles.
5. Hope that this is my final problem and the ABS self test positively and I have ABS.
Thats my current thinking,so maybe someone else has another way of solving the issue  Grin
« Reply #1121 on: January 10, 2016, 10:11:28 AM »
I would be fitting vs front sealed hubs so its reading the same trigger points front and rear .
As it is it will be getting mixed signals thinking the ABS needs to active.
Im sure the amount of teeth wont matter just as long as its even front and rear?
DJ
« Reply #1122 on: January 10, 2016, 10:43:56 AM »
I think it was just accepted as the norm.
0417 270 315
« Reply #1123 on: January 10, 2016, 11:29:07 AM »
Front wheel hubs could work, will get Dino to get a pair tomorrow as like you said will match the rear.
It just leaves the different tyre sizes and the pulse ring off the tailshaft.
« Last Edit: January 10, 2016, 11:40:09 AM by JB » Logged
« Reply #1124 on: January 12, 2016, 05:13:28 PM »
I am still trying to work out how many weeks would be appropriate if I were to calculate an appropriate change of name for my builds  Undecided
I am enjoying watching the progress.
« Reply #1125 on: January 12, 2016, 10:59:08 PM »
We have an active ABS!!!
Thanks Pete for the hub suggestion.
A bit of research while at work tonight and the pulse ring on the tailshaft is actually the speed sensor.
Happy days, it has been a bit of a process to sort the bugs with the ABS,
« Reply #1126 on: January 13, 2016, 12:24:55 PM »
It's now that I realise I have three abs units I could have sent for nothing. At least you found it. Congrats
GOA350
« Reply #1127 on: February 03, 2016, 08:20:10 PM »
Now for the trip to Toowoomba  Wink
« Reply #1128 on: February 05, 2016, 10:18:44 AM »
So here is that last photo while it is in the project car section.
The upholstery has been in full swing and will be finished by the 12th of March.
After discussions with the head of Vic Roads who deals with modifications, Victoria does not recognise the Queensland engiineering blue plate. So I have to finish the car, the put it on a truck to Brisbane. Then fly to Brissy on the 22nd, get the roadworthy and registration in Brisbane, then drive to Toowoomba from there.
After the Nationals I will then drive it home where the registration can simply be changed over to a Victorian plate as it has now been registered before. So even though everything has been done in accordance with the new Australian standards that came in recently the states are still in the dark ages. It is very frustrating, but nothing I can do.
Safe driving everyone.
freddyc
« Reply #1129 on: February 05, 2016, 07:22:05 PM »
Jason was up in Yungaburra week and was reminising about meeting you in the big shed there. it is still there by the way. So long ago.
fred
Townsville North Queensland
« Reply #1130 on: February 07, 2016, 07:03:52 AM »
Was only when all this was just starting Fred!
« Reply #1131 on: March 07, 2016, 06:42:39 PM »
It is finished!! Grin
More pictures to come after the Nationals.
So looking at the original title I only missed it by 2135 days, as by tomorrow it will have been exactly 2500 days since I first started on the car.
It is amazing to reflect back and think of how many people have been involved in this build from advice and ideas, to that of help with parts old and new.
Too many to list here but to all of you that have helped me along the way big and small I thank you, every bit of help has been appreciated.
Hopefully see a lot of you at the Nationals...
FCV08
FE FC Club of QLD
« Reply #1132 on: March 07, 2016, 06:59:10 PM »
Congratulations JB well done
Looks fantastic.
Looking forward to seeing it in a few weeks.
Now you have to move your post to that other one (Completed Projects)  Grin Grin Grin
Craig D
JOX515
« Reply #1133 on: March 07, 2016, 07:07:16 PM »
Woohoo JB, very well done and hope you get many many miles of enjoyment from it.  Graeme
DJ
« Reply #1134 on: March 07, 2016, 07:08:26 PM »
Congratulations JB, it looks terrific.
Unable to make the Nats so looking forward to more photos.
0417 270 315
snuff69
« Reply #1135 on: March 07, 2016, 07:10:50 PM »
YEEEEEEEHAAAAAA   can't wait to see it in Toowoomba JB. The ute looks amazing.    Dave
camxsmith
« Reply #1136 on: March 07, 2016, 09:11:11 PM »
Awesome JB great picture, can not wait to see the other pics, congrats
KFH
« Reply #1137 on: March 07, 2016, 09:46:28 PM »
Looks awesome JB. Well done.  Looking forward to seeing it in Toowoomba
« Reply #1138 on: March 08, 2016, 07:55:44 AM »
Awesome work mate. Can't wait to see it in the fleah
VAN059
Brisbane, QLD.
« Reply #1139 on: March 08, 2016, 08:30:19 AM »
Great job JB, I won't be in Toowoomba unfortunately, but can't wait for the pics.
Cheers Marc
Pages: 1 ... 55 56 [57] 58 59 60   Go Up
Page created in 0.041 seconds with 15 queries.
