April 18, 2025, 05:01:13 AM *
Author Topic: TWIN CARB LIKAGES  (Read 3405 times)
robbo
« on: April 23, 2009, 08:34:00 PM »
Hi all,
I've recently fitted twin carbs and extractors to my grey motor.
And I'm not happy with the W clip and rod set up between the 2 carbs.
I'm keen to see what other guys are using on their grey motors.
« Reply #1 on: April 23, 2009, 09:21:30 PM »
The 2 W clips and rod is a pretty standard set up for carbies in line that way. You have to be able to accommodate a little bit of misalignment between the carbies.
FATBOY
« Reply #2 on: April 23, 2009, 09:54:42 PM »
Ive got them on my twins was a bit sceptical at first but have given me no trouble
regards fatboy
ps i run a cable not mechanical linkages
fatboy
0414712441
robbo
« Reply #3 on: April 24, 2009, 11:10:36 AM »
Thanks for the input guys.
With my set up, I found that after I use the choke, (which is on the front carby)
 my front carby alignment has moved.
I have tightened the W clips heaps but you can still move one of them on the shaft?
I have a mechanical link for accelerator  on the rear carby.
ezzacoombs
« Reply #4 on: April 24, 2009, 09:14:40 PM »
hey
i was looking at a few of the carby set up's at the easter show of 2 of the grey motors and they were both different to eachother and different to mine. Not sure what a W clip is, but i have a bar which runs along, the bottom of the manifold which has 2 shorter bars which come off this bar and go to arms linking to one carby each and another bar which has a control arm on it which goes to a mechanical accel set up. i find this works really well and that the choke does not effect it. the only trouble i had was that the carvies were not fulli opening. but i fixed that soon enough.
thanks mate..
robbo
« Reply #5 on: April 24, 2009, 10:00:20 PM »
sweet thats what I'm interested in. do you have any pics ezzacoombs Cool
ezzacoombs
« Reply #6 on: April 25, 2009, 08:19:42 AM »
robbo,
i just took the carbies and manifold off and sent them to extreme to get rebuilt and polished and shined and i will be getting them back next friday. the manifold which i have had 3 loops i guess you could call them, and this "pole" (great at using terminoligy i am) goes through these loops on the outside bottom edge of the manifold. ill see if i can find this setup on the internet somewhere and send it to you. damn i should have taken a few picks before i took it down to the carby place.
but If you ever need to get any carbies looking fantasticly shinny and rebuild this guy does a great job, he can take it back to the brass looking finish or he can make it look like polished alloy. i saw a few which he has done. look amazing, i also took the manifold in to him and he will clean that up too. Great bloke "Extreme fuel systems" look on google.
thanks mate
Page created in 0.033 seconds with 17 queries.
