August 29, 2025, 07:27:57 PM *
Author Topic: ignition leads  (Read 11232 times)
Utemad
« on: April 12, 2009, 05:28:27 PM »
I have been having a lot of trouble trying to find a black set of leads for my fe Huh Huh. It is an original car and i dont want to put the irridescent blue ones on that the auto stores sell. Does anyone know who makes or sells original style leads? Or at least where i can find black leads. Any info would be appreciated.
Cheers Brent
FX1975
« Reply #1 on: April 12, 2009, 09:03:52 PM »
Hello, Vintage wiring harnesses make these up their no. 03 9870 0583
                                    Hope this helps
                                                Frank
CraigA
« Reply #2 on: April 12, 2009, 09:10:17 PM »
You can also try this guy.
http://www.qldignitionleads.com/
Utemad
« Reply #3 on: April 14, 2009, 08:57:28 AM »
Thanks guys. Quick replies! Grin Grin
Papa Smurf
« Reply #4 on: April 20, 2009, 10:45:55 AM »
Were they 8mm or 9mm originally
Utemad
« Reply #5 on: April 21, 2009, 07:51:39 AM »
Hi guys.
Got my leads yesterday - they look fantastic. Very happy Jan. Cheap too. Grin Grin
« Reply #6 on: April 21, 2009, 04:00:04 PM »
Which of the suggested suppliers did you go with? It would be good to know who you're giving the ups to.
Utemad
« Reply #7 on: April 22, 2009, 08:31:40 AM »
Vintage Wiring Harnesses - very quick and professional.
greyone
« Reply #8 on: April 23, 2009, 11:07:59 PM »
after reading this I ordered my leads from vwlooms $38& $6 del should be here in the morning can,t wait
regards mal
TTV6FC
« Reply #9 on: April 24, 2009, 10:11:19 PM »
Careful Mal,you need a loom for an FC,not a VW.... Tongue
Maco
« Reply #10 on: April 29, 2009, 02:27:47 PM »
Can some one put up some photos of the leads fitted to a motor.
Maco Grin
Better in Green
greyone
« Reply #11 on: April 30, 2009, 08:44:38 PM »
maco check out the photo of the oil filter in accessories theres a good shot of the leads
regards mal
greyone
« Reply #12 on: May 09, 2009, 11:37:23 AM »
got my leads coil lead was to short and #2 also to short maybe cause of the filter?
anyway I had thurs off so drove car to ringwood swapped leads around now perfect fit he also pointed out that measurements were from an fj I thought they would have been the same maybe not
regards mal
« Reply #13 on: May 09, 2009, 11:51:59 AM »
FJ leads have right angle fittings so I'm not surprised that some leads were short. The lead would need to be maybe 20 or 30 mm longer to suit a straight fitting.
greyone
« Reply #14 on: May 09, 2009, 09:34:07 PM »
well it turns out the leads that vintage wiring harneses make up are for fj not fe fc will speak to them next week and see if they will do them for fe fc,ken if you read this could you give me the length of 1,2,3,4 terminal to terminal as these are the ones they make with 90degree fittings
regards mal
« Reply #15 on: May 10, 2009, 10:18:35 AM »
Unfortunately I don't have a stock car here any more - I'm sure others can provide the lengths though.
Maco
« Reply #16 on: May 10, 2009, 08:47:58 PM »
Any photos
Maco
Better in Green
