August 24, 2025, 01:04:20 PM *
Author Topic: Clutch X Mark  (Read 2109 times)
mc54
« on: March 26, 2009, 06:19:51 PM »
Hi All
I am replacing my clutch and I was reading in the manual to check that the "X" mark on the clutch cover is aligned with the "X" mark on the flywheel flange.
I have looked and cannot find an alignment mark on either one. I was under the impression that the pressure plate did not have a specific way to be lined up (there is no top or
bottom or left or right).
Also since I am replacing the pressure plate, what if the new one had no alignment mark?
Can someone please explain what they mean by this mark and why it is there.
Mike
« Reply #1 on: March 26, 2009, 08:11:00 PM »
They use to mark the balance point  on some cars with an x for pressure plate alignment now days most engines are negatively balanced not sure if this is the case with early Holdens ........FC427.......
« Reply #2 on: March 26, 2009, 09:13:20 PM »
Only original clutch pressure plates and flywheels have this mark - they were put on from the factory, but after a flywheel grind and a new clutch installed, all the marks are long gone. I have seen the occasional pressure plate with the X on it, but few and far between.
mc54
« Reply #3 on: March 28, 2009, 06:09:03 AM »
Thanks Guys
Now I won't be looking for something that isn't there.
Mike
Page created in 0.021 seconds with 16 queries.
