August 24, 2025, 11:39:04 AM *
Author Topic: Hub/Spindle movement  (Read 2017 times)
Online Online
« on: March 25, 2009, 08:52:55 PM »
When the spindle/hub are fitted to the car but without the steering arm connected, should the spindle/hub "steer" freely or should there be some resistance?
« Reply #1 on: March 25, 2009, 11:29:00 PM »
Stinky,
Assuming that you have new balljoints there should be some resistance, however if the balljoints are used than it should turn fairly freely
Online Online
« Reply #2 on: March 25, 2009, 11:51:27 PM »
The ball-joints are only 3334 miles old (just checked Grin) but they just seem really tight  Huh
« Reply #3 on: March 26, 2009, 12:47:31 AM »
Stinky,
There are two types of balljoints, one is the standard balljoint, that is greasable. this normlly have metal parts inside them, cups springs etc and wear out fairly quickly. The other type is what they call nylon encapsulated, these are non greasable. This is where they have a nylon (teflon) type of material that encapsulates the ball and is basically poured into the balljoint housing under pressure. these can be very stiff for some time, they require no grease because there is no metal on metal wear.
Which type do you have?
Online Online
« Reply #4 on: March 26, 2009, 08:26:14 AM »
Standard grease-able type and they are chokkas with grease  Grin I guess I just have to put a few more (thousand) miles on them  Grin
Page created in 0.021 seconds with 18 queries.
