August 31, 2025, 01:01:58 AM *
Author Topic: floor pan and sill replacement  (Read 5282 times)
FC P/VAN
« on: February 18, 2009, 08:24:50 AM »
I need to replace both front floor sections in my wagon and outer sills, lower "A" pillar sections are pretty bad also, should i do floors before sills or other way around??? possibly need to do inner sills also depending on what i find when i remove the outers.
Johns
Model: something else...
« Reply #1 on: February 18, 2009, 09:00:52 AM »
This article is in the Technical section of the site
http://www.fefcholden.org.au/techinfo/tech001.html
I would do the sills first, one side at a time, in case you find you have to repair inners as well.
FC P/VAN
« Reply #2 on: February 18, 2009, 01:53:44 PM »
thank you so very much for that link, a very informative read on exactly the job i am about to undertake.
cheers FC P/Van
« Reply #3 on: February 18, 2009, 03:19:25 PM »
I did the sills first (inner then outer,cut the outer off first) then all floor sections.Doing it this way helps to maintain some alignment of the B pillar.I also had the advantage of doing it on the rotisserie so I was able to put the car on it's side to take the load off the sills and floor.Be sure to try the doors back on the car with the sill tacked in place as I've seen what can happen if you don't.Get all your door gaps right before you completely weld the sill.I think this is all in the techinfo anyway.I have posted a lot of pictures in my thread "It has begun,but will it continue".Cheers,Jamie.
« Reply #4 on: February 20, 2009, 12:05:40 PM »
Definately very important I bought a wagon project years ago that had already had the sills done, looked like everything had been done well, only trouble was the back doors didn't fit inside the frame.
                                     Pedro
Page created in 0.042 seconds with 16 queries.
