August 01, 2025, 10:57:06 PM *
Author Topic: Interchangeable doors. Sedan - Wagon  (Read 2540 times)
hrpremier
Jason
Jason Fewins
« on: February 09, 2009, 12:49:17 PM »
Done a quick search but failed to find an answer.
Saw some FC Doors advertised locally.  Been told by seller two rear wagon doors in good nick. Pair of Front doors have rust in lower section byt are straight (Unknown source ie sedan or wagon for fronts).  Are doors between models interchangeable. IE wagon doors fit on a sedan or vise versa front an or rear.
Thanks in advance
Jase.
FC P/VAN
« Reply #1 on: February 09, 2009, 01:03:21 PM »
sedan, wagon and p/van door shells are all interchangable for fronts.
genuine p/van driver door does not have a lock barrel though.
ute front have a radiused upper rear window frame edge (unique to utes)
sedan and wagon rears are different shaped rear 1/4 window frames.
between fe and fc all shells are interchangable (with appropriate body styles as above)
hope this helps.
cheers FC P/Van
« Reply #2 on: February 11, 2009, 07:42:05 PM »
Just to add to P/van's comments -
All FE and FC vans, utes, standard sedans, standard wagons and business sedans only had a lock on the passenger door.  Only special sedans and wagons had 2 door locks
FC P/VAN
« Reply #3 on: February 11, 2009, 07:46:16 PM »
cheers for that little info Ken, I am always learning new things on this site too, love to help others as much as I can and i know i will get knowledge in return for things I am researching.
cheers FC P/Van
