July 29, 2025, 11:18:46 AM *
Author Topic: Door Trim Mouldings  (Read 2552 times)
Ken's 57
« on: January 19, 2009, 10:19:33 AM »
Could anyone tell me if removing the moulding strip on top of the door trim and then replacing it again can be a problem? I'd like to re-tension the smaller Cosmos Grey insert to remove the slight ripple but it might be wiser to leave well enough alone. As you can see it's not major. According to the workshop manual it's a press fit so I'm thinking I might strike trouble trying to get it back on again without damaging it - especially where it curves around at the front section.
Cheers...Ken
« Reply #1 on: January 19, 2009, 10:32:50 AM »
They come off and go on easily .....Just a thought you may be able to leave it on and just give it a little heat to shrink the vinyl ,use a heat gun and be very carefull not to get to close and burn the vinyl ........FC427.......
CraigA
« Reply #2 on: January 19, 2009, 11:09:03 AM »
Mark's right, they are generally easy to remove/refit.
If you are worried spray the material with Armourall or similar, this will let the metal trim slide on more easily.
Online Online
« Reply #3 on: January 19, 2009, 11:09:35 AM »
Try removing the arm-rest and getting it settle the other way first.
On standard trims getting the top trims off and on is not a problem, if you have trouble getting them to stay on when replaced a few taps with a rubber mallet should close them up enough to "bite".
Ken's 57
« Reply #4 on: January 19, 2009, 05:46:49 PM »
Cheers everyone - thanks.
