July 28, 2025, 05:24:30 AM *
Author Topic: Recommend mechanics in Perth for beloved FC?  (Read 1832 times)
UFC000
« on: January 17, 2009, 02:31:32 PM »
Hi have been looking in forums for a while, but first post. We have owned a near original FC for last 6 months, all was sweet with near daily use and usual TLC until Thursday when on 40 C day my wifehad to do an extended run around the suburbs. Apparently it gave a massive backfire and then died in Thornlie full of wife and kids. A couple of us went out to see if we could resurrect her, but something horrible appears to have happened to timing and would not start (but no nasty noises). I am not mechanical, but have been told to expect either stripped timing gear or cracked head at this stage...anyway, upshot is I am looking for recommendations for a suitable mechanic in Perth (ideally somewhere near Welshpool or Osbourne Park) to entrust the FC to. Any suggestions?
« Last Edit: January 17, 2009, 03:55:53 PM by stinky » Logged
« Reply #1 on: January 17, 2009, 04:01:30 PM »
I can't help with the mechanics, but a quick way to see if it is the dizzy or timing gear, pop the dizzy cap and crank the motor (by hand is probably safest) if the rotor arm moves the dizzy gear is OK. To check if the timing gear is still there take of the oil fill cap and crank the motor again and look for rocker movement. Not a definitive test, but may help with diagnosis.
UFC000
« Reply #2 on: January 17, 2009, 05:11:30 PM »
Thanks for those tips, will do these checks. Don't think it could be the head as no emulsion in oil and water levels all fine. cheers.
