August 15, 2025, 04:39:19 AM *
Author Topic: Cracked windscreen - how do I stop it....  (Read 4947 times)
Paul In Ireland
« on: January 13, 2009, 12:10:02 PM »
The FE front screen has a crack about 200mm long in the top passenger corner. Can I drill a small hole in front of the edge of the crack and will that stop it? I don't know how long it's there or how fast it is moving but I want to stop it as replacements are a bit hard to come by over here (the French hoard them all  Wink).
Paul
 Cool
jack_fc
SouthWest Coast, Victoria
« Reply #1 on: January 13, 2009, 12:20:58 PM »
Hey Paul; the French are supposedly known for their style and good taste - surely they would only be hoarding the FC windscreens??     Wink Wink Wink
mc54
« Reply #2 on: January 13, 2009, 12:45:16 PM »
Paul
I would contact an expert, they drill a small hole and fill with a clear resin.
like this place
http://www.autorisk.com/auto/Windshield%20Repair.htm
hope you can find one local.
Mike
jack_fc
« Reply #3 on: January 13, 2009, 04:37:05 PM »
Hey Paul,
 what Mike says is the best way. A friend of mine is in the windscreen repair business - he recommends as Mike says....    (why is that not surprising???)
However, if this is not a viable option for you, he said you could try drilling the smallest hole possible (make sure it covers the very end of the crack) and fill with araldite or similar...  He stresses that this is the "bush mechanics" way, and COULD (maybe) prevent the crack spreading, BUT could also result in tears and anguish...   your call!
cheers jack
ps   He said filling the hole fully and without contamination or bubbles, and keeping the surrounding area clear of araldite may be a challenge for the amateur repairer. Understandably, he wasn't really forthcoming with more info - maybe others here can give more detailed instructions??
mc54
« Reply #4 on: January 15, 2009, 04:55:55 AM »
Paul
Just a one more thing. I am assuming that because there is a crack in the windscreen and it has not shattered that it is laminated.
This can be drilled. So can ordinary glass, but not toughened. I believe that toughened glass is heat treated which gives it a hard
coating on the outside which creates pressure, if the glass is drilled, chipped, or cracked past the hardening the pressure is no longer
even and it shatters. Something like that.
Mike
DN2168
See you on the road Skag!!
dean.nommensen
« Reply #5 on: January 16, 2009, 08:25:42 AM »
Paul,  Find an insurance company that has a free windscren clause, wait a couple of months then let them worry about it  Grin Grin.
Dean.
Paul In Ireland
« Reply #6 on: January 16, 2009, 08:29:18 AM »
Already thought of it but I'd say they will baulk if I try it.
We spend a fortune insuring our cars but the bastards will never pay out!
Paul In Ireland
« Reply #7 on: January 20, 2009, 01:24:32 PM »
So, nobody seems willing to do this - so I'll attempt it myself.
My only question would be this - do I drill into the end of the crack or just barely past the end and let the crack "find the drill hole"?
 Cool
mc54
« Reply #8 on: January 20, 2009, 03:37:35 PM »
Paul
Try this link
http://www.car-accessories-magazine.com/windshield-repair-kit.html
It has information on how to do it.
Mike
crashbox
cruzin in the FC
« Reply #9 on: January 20, 2009, 10:48:55 PM »
g'day, Smiley
ok this seems bodgey, but it works!....grab sum heavy duty arledite type glue, gentley scrape chip/crack in screen, use masking tape around area so you dont make a mess, mix glue a throw it in crack... yes it works , my cuz has a chopped ford f250, got a new screen made , yep got a bad stone chip/crack fisrt outing and used this method, windscreen still in truck,crack has not got worse after 7months... and i ACTUALLY  saw it tonite ! Wink
wot have ya got to lose! Grin
mr c
"A GOOD HOLDEN IS A CRUZIN HOLDEN"
