June 03, 2025, 11:50:47 PM *
Author Topic: WHAT FUEL TANL CAN I USE  (Read 4365 times)
junkyard dog
« on: November 09, 2008, 09:16:56 AM »
HI EVERYONE I HAVE NO TANK & WANTED TO SEE IF ANY THING ELSE FITS???
« Reply #1 on: November 09, 2008, 10:33:18 AM »
Anything can be made to fit, with enough time, steel and a welder  Wink
A few people have fitted various tanks over the years, doing a search (up the top of the page) should turn up a few options. Otherwise a wanted ad for a tank or if you are cashed up there is a bloke that makes stainless tanks, Ed should be able to help with contact details.
waynos
patience grasshopper
« Reply #2 on: November 10, 2008, 12:45:32 AM »
streetneat does a nice stainless tank not sure how much though
cruiser056
cruisin to the rock and roll
« Reply #3 on: November 10, 2008, 07:34:03 AM »
If it is a sedan, then a LC LJ Torana tank will fit in!  Although this may be just as hard to find as a FE FC tank.
FCOV6
« Reply #4 on: November 11, 2008, 08:35:50 AM »
From what i have been reading on the forum, about the cheapest and easiest tank to source and fit is from a VN- VS commodore , this will also help with an efi motor as they have the pump in the tank already.
 I picked 1 up for a dollar ! XA-XC ford tanks fit and have a spare wheel well in them but they will be expensive if they are dent/ rust free.
junkyard dog
« Reply #5 on: November 12, 2008, 07:37:01 PM »
How does the vn tank fit does'nt it have straps to hold it in?Huh?
« Reply #6 on: November 12, 2008, 09:53:50 PM »
Yes - cut out the old floor section and replace / rebuild to suit the VN tank and tank strap mounts. Other than the LC LJ tank, which I wasn't aware of - everything else will require metal fabrication and modification to make it fit.
