August 24, 2025, 12:55:04 PM *
Author Topic: HK/T/G Column Auto Gear Select Indicator  (Read 1685 times)
FB_MAD
« on: October 25, 2008, 06:28:36 PM »
Looking for a HK,HT,HG Column Auto Gear Select Indicator to suit TRIMATIC shift pattern,that is, showing "L S D N R P".
I have a Powerglide one that shows "L D N R P" but need the Trimatic shift pattern.
Doesn't matter if it's a bit worse for wear as long as the letters printed on the backing plate are in good nick and readable I can swap it over to my Powerglide one.
All constructive leads and help appreciated,
Terry.
Has anybody seen my red pen??
« Reply #1 on: October 25, 2008, 08:49:13 PM »
I have an indicator but not sure whether it is HKTG or Torana. It is made of black plastic and the clear plastic bit with the letters on it seems to be either glued in place or moulded in place. I would say that it would have to be cut out carefully to insert into another housing. The display definately reads "L" "S" "D" "N" "R" then a space to "Park"
FB_MAD
« Reply #2 on: October 25, 2008, 09:43:54 PM »
Thanks Ken,
If it's Ok, I'll give you a call on the phone tomorrow if that's all right with you ??
Terry.
« Reply #3 on: October 25, 2008, 10:34:53 PM »
No problems Terry - best about lunch time
