September 09, 2025, 10:04:52 PM *
Author Topic: fc v8 chassis kit  (Read 4267 times)
ofc304
« on: October 22, 2008, 06:58:11 PM »
does anyone have a chassis kit for v8 to fc or good pics of kit in se qld thanks Glenn Smiley
gwuthie
« Reply #1 on: February 01, 2009, 02:33:24 AM »
ofc304, not me but could someone inform me of what makes up the kit and is it the kind of thing I could DIY??
ratbox
« Reply #2 on: February 01, 2009, 05:14:45 PM »
if you can weld and have the measurements it would be a piece of cake there have been plenty done
« Reply #3 on: February 01, 2009, 07:07:58 PM »
The kit that I got had :
- two main chassis rails, "U" channels secured with bolts through the existing support rail at the front and welded to chassis just in front of the forward rear spring hanger bracket.
- Gearbox mount
- Tailshaft loop
- Sub-frame connectors, bolt up to the subframe and then the "U" channels on the main rails.
I think the V8 kits have a plate to weld to the bottom of the HR front-end too.
This is a DIY Kit, so if you are handy with a welder and/or are getting the car engineered you could do a lot better.
A search of the site should turn up some pics, there have been plenty over the years.
gwuthie
« Reply #4 on: February 03, 2009, 10:41:13 AM »
thanks guys. I thought that the kits were nothing special and you've confirmed it for me
ezzacoombs
« Reply #5 on: April 16, 2009, 12:51:12 AM »
where are you able to get these kits from??
« Reply #6 on: April 16, 2009, 12:56:46 AM »
Castlemaine Rod Shop - http://www.rodshop.com.au
