August 25, 2025, 11:51:07 AM *
Author Topic: Re: V8 STAINLESS EXHAUST  (Read 3639 times)
« on: December 10, 2002, 10:14:16 PM »
Hi Chris,
Im interested depending on how hard up against the block the original manifolds are.
I have modified my steering for max clearance (still not heaps).
would you allow a try before you buy arrangement?
« Reply #1 on: December 11, 2002, 02:36:14 AM »
oops, forgot holdens werent powered by Holden any longer.
in that case, the motor for $150 is a great deal  Wink
thx
FCV8UTE
« Reply #2 on: December 11, 2002, 07:51:38 AM »
ED,EVEN IF YOU USE VT 5LT MANIFOLDS THEY STILL WON`T BOLT UPTO YOUR HEADS BECAUSE ALL 5 LT INJECTED EXHAUST PORTS ARE IN DIFFERENT POSITIONS TO THE EARLY HEADS.AND TAKE IT FROM ME THERE IS NO ROOM FOR ANY STANDARD MANIFOLD TO EXIT WITHOUT HITTING EVERYWHERE(BELIEVE ME I TRIED)SORRY TO DISSAPOINT YOU
BRAD (FCV8UTE).
PS IF YOU ARE HANDY WITH A TIG WELDER AND A BLO TORCH U ARE BETTER OFF BOLTING YOUR ENGINE TO AN ENGINE STAND AND BUYING A BAG OF MANDREL BENDS FROM ANY EXHAUST SUPPLY WAREHOUSE AND MAKE  ;)YOUR OWN BLOCK HUGGERS.THEN THEY`LL FIT
« Reply #3 on: December 11, 2002, 09:52:23 PM »
HI FCV8UTE,
Since my last pics I have changed my heads to VN style late model heads, Harrop manifold etc.
I also reworked the steering column by lengthening the lower section apporx 1.5 inches to allow a better steering rod angle. (see pic)
I was hoping that maybe a stocky type exhaust manifold may fit up to save me the hassle of making a set of headers to suit.
From my understanding, headers can be pretty tricky to make.  I always like to have a go before shelling out dollars for someone elses work, but do u reckon an exhaust like yours would be hard to make for a first timer?
« Reply #4 on: January 01, 2003, 09:14:12 AM »
Hi ED,
Am just in the process of doing the extractors for the V6 and have found them to be fairly easy. Started with two mounting flanges, 10 90 degree bends and 2 collectors...Cut and weld to suit... After I'm done am getting them HPC coated. Tight fit on the drivers side but look pretty good.
Jason.  Grin
Geoffs Fe Ute
« Reply #5 on: January 02, 2003, 11:34:38 AM »
Ace.
Interested in the Vu exhaust.Do you know what the difference is between an SS and a standard 5.7 executive VX exhaust.
Geoff
« Reply #6 on: January 07, 2003, 06:24:22 AM »
Hi Jason,
Thanks, I also spoke to Brad, who has given me some pointers.
Will start ASAP.
