September 08, 2025, 06:12:32 AM *
Author Topic: coloum change  (Read 5467 times)
kiwi FC
« on: September 09, 2008, 05:05:20 PM »
Hi guys when i got my FC it had been convreted to floor change with an 3spd EH box . I want to change it back to coloum change but the FC rods from the gearbox to the coloum linkage wont fit . Will the EH ones fit?
Cheers Bryce Huh
« Reply #1 on: September 09, 2008, 06:28:25 PM »
I had a HR G/box in my FC and a HR column and the linkages worked fine so can't see why not, as your doing the same conversion only using EH column to the same G/Box ........FC427......
kiwi FC
« Reply #2 on: September 10, 2008, 10:18:36 AM »
The slector linkage comes out of the side of the gear box but the rods are shaped for the linkage to come out of the bottom of the box?
« Reply #3 on: September 10, 2008, 10:28:17 AM »
Sorry Kiwi FC I should have said you will need to change the Column to EH or HR to get back to three on the tree for the linkages to work out, have never seen it done with the FC column ......FC427.......
kiwi FC
« Reply #4 on: September 10, 2008, 03:43:04 PM »
  how hard do you think it would be to make some?
Thanks for the help
Bryce Wink
« Reply #5 on: September 10, 2008, 04:50:00 PM »
Bryce making the linkages would not be hard but first you would have to compair the the movement of the selectors at the bottom of the FC column against the movement of a EH /HD /HR type to know if it will be OK.......FC427.......
kiwi FC
« Reply #6 on: September 11, 2008, 10:29:45 AM »
Thanks very much for the help . Im new to this so I may have some stupid questions.
Spinner
« Reply #7 on: September 11, 2008, 11:04:37 PM »
I gotta say that the only stupid questions are the ones that you don't ask.
If you don't know, then ask as ask.  Ask again to be sure if you think you need to.  Lotsa blokes here are quite happy to share their knowledge.
Page created in 0.041 seconds with 16 queries.
