July 27, 2025, 04:08:31 PM *
Author Topic: Wheels  (Read 4910 times)
FCman
« on: August 19, 2008, 04:07:40 PM »
G/day all.
Can someone help.I want to fit 14" wheels to my FC,standard hubs and drums fitted,does anyone
know what model wheels will fit?
FCMAN
Sunshine FC
NosFEratu
F4+ =^^=
« Reply #1 on: August 19, 2008, 05:03:02 PM »
Hi FCMAN and welcome
I have a completely standard FE front end with brand new standard offset HT rims - no need to fit HT hubs. HG rims are OK to use too.
Don't use HK rims - your wheels won't turn because of the inside offset fouling the tie-rod end. HK rims have little slots in the outer part of the centre (if that makes sense to you) and they have a deeper back spacing – this explains the different standard track measurement between HK's and HT/G's.
Check my avatar – I’ve been running HT rims for over 7 years now.  I use my car regularly and have had no problems with them at all - absolutely no scraping or interference (it’s also lowered 2" all around).
Hope this helps you.
Kathi  Cool
F4+ =^^=
NosFEratu
« Reply #2 on: August 19, 2008, 05:54:49 PM »
Hi FCMAN OR try early Volvo wheels same PCD as early Holden ......FC427........
FCman
« Reply #3 on: August 20, 2008, 09:57:02 AM »
Thanks very much Kathi and FC427,I will give em a try.
FCMAN
Sunshine FC
waynos
patience grasshopper
« Reply #4 on: August 20, 2008, 08:22:25 PM »
a guy at the wreckers the other week ,when i was trying to get some ht rims too,said f@#d focus wheels fit.
you cant believe much they say from my experience though
surferboy
10,000 POINTS !
« Reply #5 on: August 23, 2008, 11:29:16 PM »
Cathys'  "Ugly Duckling" FE  has got 14" Volvo rims which fit on it. BUT the wheel nuts don't fit !?
( but not being mechanically minded i don't know if they are FE drums ?)
 Cool Cool Cool
cruisin's great with a 58
« Reply #6 on: August 26, 2008, 09:31:52 AM »
Your wheel studs look short in the photo, what is the length - I can't read it. Also it looks like the Volvo rims need HQ wheel nuts with the deeper taper - this will help a lot.
surferboy
10,000 POINTS !
« Reply #7 on: August 27, 2008, 02:32:29 PM »
thanks Ken
thats 20mm of stud
was thinking about putting chromed dome nuts on ( i've painted the wheels black in a pitiful attempt to make the sedan look 1/2 decent)
or fitting different rims when i need new tyres (but the usual question of which rim raises its ugly head)
if 20mm stud is too short how do i make them longer.......silly question, why would they make short studs if wheels/nuts wont fit on ?
 Cool Cool Cool
sorry my mechanical skills are worse than my photography skills
