May 14, 2025, 12:39:09 AM *
Author Topic: Interior Door Handle Spacer Plates  (Read 3087 times)
Ken's 57
« on: August 16, 2008, 03:57:11 PM »
Would anyone have a couple of interior door handle spacer plates please? For some reason my front ones are thinner than the rears and it was really difficult to get the tool in between to get the spring clips to release. Because they're thinner the leading edges are also quite sharp and they have begun to cut into the trim. Not sure if they are repros or what's going on?? Thanks.
Cheers......Ken
« Reply #1 on: August 16, 2008, 05:59:09 PM »
They get worn down by the winder handles and end up razor sharp and difficult to remove as you have described. They aren't repros, just worn out. Chuck them away and get some good ones. I have dozens here but you should be able to pick some up in the NSW club
Ken's 57
« Reply #2 on: August 16, 2008, 10:27:05 PM »
Thanks Ken. Hopefully someone in NSW can help.
Cheers......Ken
« Reply #3 on: August 24, 2008, 04:29:13 PM »
Not wanting to argue with you Ken, but I thought Rares did plastic ones? They might not be for the FE/FC but same as the metal ones just plastic.
colt
« Reply #4 on: August 24, 2008, 08:47:46 PM »
Later models have plastic ones, not sure which model they started with, maybe EJ. They are a straight swap, not much good for originality though.
Colin.
colt
« Reply #5 on: August 24, 2008, 09:16:26 PM »
I thought the plastic started in HK's and EJ EH HD HR still had the metal Huh Huh Huh.......FC427.......
« Reply #6 on: August 26, 2008, 09:55:41 AM »
Yes plastic started in HK, they are a straight swap and can be used if originality is not an issue. Smiley
graham_fuller
« Reply #7 on: August 26, 2008, 02:46:19 PM »
As Ken said they are a direct replacement and they do save the trim. I have spare metal ones if you want them.
Ken's 57
« Reply #8 on: August 26, 2008, 06:10:48 PM »
Thanks Graham. PM sent. Smiley
