September 08, 2025, 11:21:10 PM *
Author Topic: Oil filter connections  (Read 1868 times)
FB_Ute
« on: August 02, 2008, 06:30:08 PM »
Hello all,
Q pls:  Am I correct that the connections for a Ryco oil filter go into plugs 1 and 2, and that the oil filter inlet connects to plug 1?
Also, does anyone know what 3 and 4 are used for?
Many thanks!
Cheers .... jacquie
« Reply #1 on: August 02, 2008, 08:07:03 PM »
No, the oil filter inlet comes from 1 which is the oil pressure switch hole. You need a T piece adapter to suit. The return hole is 2. Maybe the other holes are drilled for manufacturing purposes and then blocked later.
FB_Ute
« Reply #2 on: August 03, 2008, 05:49:38 AM »
Thank you, Ken.
Cheers .... jacquie
