September 07, 2025, 02:03:18 PM *
Author Topic: Front Door Rubber  (Read 1894 times)
KFH
« on: August 01, 2008, 06:44:32 PM »
I am now starting to work on the body and have found the the original outer door rubber has, on the front of car side, an molded to it a  flat section that goes between the body and the guard.  Replacement rubbers do not have this profile.  What do others do?  Forget about this flat section of rubber?  I can attach a picture if necessary?
« Reply #1 on: August 01, 2008, 10:17:59 PM »
Unless you get NOS rubbers you will have to use a repro rubber without this flap. This is not a problem in itself, but a mistake a lot of people make is not replacing this strip of rubber when the guard is put on. It makes a slight difference to the way the guard fits and also stops water going between the guard and the body.
KFH
« Reply #2 on: August 02, 2008, 05:41:27 PM »
Thanks Ken
  I had intended fitting a strip of rubber under the guard as you described.  You have reinforced my thoughts.
