May 31, 2025, 11:52:41 PM *
Author Topic: Consider your carpet  (Read 2302 times)
« on: July 16, 2008, 01:07:52 PM »
Just thought I'd pass on some advice about trans tunnel mods.
Before you do anything, consider your carpet!
If you are going to get custom carpet then you can do pretty much anything. The best policy is KIS though as it will mean less work and probably look better in the long run.
If you want off the shelf molded carpet, don't modify or make only slight changes, if you are fitting a big trans go for a CRS Trans Tunnel or the EK Auto floor, then you can order an EK Auto carpet and it will fit.
NosFEratu
F4+ =^^=
« Reply #1 on: July 16, 2008, 01:28:23 PM »
Good advice Glenn
but don't forget that if you have modified your interior by including a console over the trans tunnel then you might be able to modify a moulded carpet set.  You may be able to cut/split the carpet at the top centre of the hump, re-heat and then weight the carpet into position either side of the tunnel and out from under the console.  The cut/split section section will be hidden under the console and will allow the carpet to "spread" more easily over the trans hump and onto the floor pan.
I'm not saying that this method will suit everyone's modifications but it might be a solution that people could consider.
Kathi  Cool
NosFEratu
Page created in 0.033 seconds with 20 queries.
