August 05, 2025, 05:47:20 AM *
Author Topic: FC Identification  (Read 4033 times)
Mark_B
« on: June 07, 2008, 04:42:49 AM »
I have finally started on the FC wagon and need some help with the date of the old girl.
The body No is FC 229-5388M which I think stands for special wagon the 5,388th of the Melbourne factory line.
Trim 254-857 Riff Red & Black
Paint 253-7773 Du-co Ascot grey over Wangarra grey
Top 253-773 (Ascot grey)
Insert 253/5300 (Wangarra grey)
I think she is a mid 1959 model but the original engine is missing so I cant date it exactly. Can anyone help with modern paint No,s for the above colours and any other way of dating the wagon more exactly so I can try and get a original engine for her.
Thanks Mark-B in Tassie
« Reply #1 on: June 07, 2008, 12:36:04 PM »
Actually Mark, it would be amongst the very last FC models produced, Nov or more likely Dec 1959 I would estimate.
PPG Technical Services department can almost certainly help you with modern equivalents of those colours. (I'm tempted - very tempted - to say dark primer and light primer, but that wouldn't be very charitable Wink)
Ring Dulux-PPG customer service, tell them the year, the paint name and code and they'll be able to find it and suggest two-pack or acrylic alternatives:
PPG Australia
Customer Service & Technical Support
13 24 24
Toll Free Fax
1800 800 819
Hope that helps,
greyone
« Reply #2 on: June 07, 2008, 02:00:18 PM »
my paint codes ascot grey
412autothane dgs ref;cxd2(79002)
spectrumfan code ha26
grey
density;1.312kg L
mix3700
addQ3372-150
     Q7152-15
     Q3981-20
     Q0002-150
wang grey
412 autothanedgsref;cwk2(79025)
spectrumfan code gh48
grey density;1.084kgL
mix 1.5L
addQ3372-170
     Q7152-30
     Q3981-40
     Q4941-40
     Q3731-30
     Q0002-250
these are the colors that went on my car
hope this helps regards mal
greyone
« Reply #3 on: June 07, 2008, 07:54:12 PM »
I should add this stuff goes over the primer and has a shinny finish to it thanks ret Undecided
regards mal
dnb
« Reply #4 on: June 07, 2008, 07:58:00 PM »
Hi Mark, not sure if this will help you or not but I rang Vic Roads here in Melbourne to see if I could get any information on my FC Sedan. Mine still has original plates, which made it a bit easier, and I gave them ID numbers etc.They sent back list of past owner history  (post codes only), original engine number when first registered and date of first reg. It would be a help if you knew the original reg number or state it was first registered in and contact them.
Cost me $14.50 for the search. Good luck, dnb
Mark_B
« Reply #5 on: June 07, 2008, 11:53:14 PM »
Thanks everyone will do some more home work. Will get the chase No and then will try  motor transport here in Tassie and then Vic.
Mark
