July 27, 2025, 04:45:17 PM *
Author Topic: Hr Front End ?  (Read 5586 times)
fe1957
Turbo Charged
« on: June 01, 2008, 07:29:02 PM »
 Smiley
I did a search but couldn't find an exact answer.
I have just bought a hr drum front and hj discs\stubs etc. Have removed the HR outrigger
Can I use the outrigger of my std fe front end??? It would be a shame to remove and then find I cant use it.
thanks in advance
Grant
OFE570
Brad
« Reply #1 on: June 01, 2008, 08:35:04 PM »
I believe you will need to use either an FB/EK or EJ outrigger to bolt onto FE/FC. Somebody else may be able to confirm this . I'm told that the standard FC/FE outrigger is not compatable with a HR front end conversion.
  I intend to use an FB outrigger on the HR front end that I have. It will be fitted to an FE body.
               Brad.
Revhead_Fc
just put a chev in it
« Reply #2 on: June 01, 2008, 10:52:33 PM »
Yeh grant Brad is correct you  will need a fb/ek or ej/eh but only the eh if you are running anything but a grey motor as the eh outrigger doesnt have the 2 engine mount holes in it. You could drill them yourself if thats all that you can get.
Ben
I958GM
« Reply #3 on: June 02, 2008, 05:25:13 PM »
Brad, if you are needing a eh one for lets say - red motor-6cylinder, there's one on E-Bay at the moment-Hope this helps-1958GM Mark
fe1957
Turbo Charged
« Reply #4 on: June 02, 2008, 08:49:19 PM »
Thanks for setting me straight on this one.
Out of interest does anyone one know why the fe fc does not fit , is it the angle of the crossmember. The length seems about the same?
Grant
OFE570
« Reply #5 on: June 02, 2008, 09:24:55 PM »
The depth of the FE FC crossmember is deeper than FB to HR
fe1957
Turbo Charged
« Reply #6 on: June 02, 2008, 09:48:05 PM »
Thanks Ken
OFE570
Brad
« Reply #7 on: June 03, 2008, 07:25:56 PM »
  Thanks for he heads up Mark . Fortunately I have a complete EK front end in the back yard .
        I have been hanging onto it for about 20 years and now have finally found a use for it.
  Well some of it anyway. Grin.
                    Brad
