June 02, 2025, 11:21:36 AM *
Author Topic: Commodore discs  (Read 4195 times)
pedro
« on: May 25, 2008, 03:29:05 PM »
Just doing a bit of research on fitting VS discs, Rod hadfield only has adaptors for HK-WB not HR front ends, I presume that means i have to fit HK-WB stub axles to the HR crossmember.
smithy
yeah its purple !
« Reply #1 on: May 25, 2008, 06:12:12 PM »
hmmm not to sure pedro, maybe there is some sizing differences with the VS discs Huh Huh Huh
try hoppers stoppers and see what they say.
dean
« Reply #2 on: May 25, 2008, 07:08:07 PM »
When Ken was at Hoppers Stoppers, I sent him down some HR drum stubs and he machines a piece off them to fit some laser cut plates that accepted my VT calipers. They also have the hubs that fit commodore rims to finish off the package. I would recommend this and would use them again.
Hope thids helps
Jason.
pedro
« Reply #3 on: May 25, 2008, 08:18:11 PM »
Thanks, Hoppers stoppers sounds like the go, were you running rack and pinion if so front or rear mounted.
sexyfc
John greco
« Reply #4 on: May 25, 2008, 10:13:59 PM »
engineer once said to me you would get a better geometry being rear mounted.. If could i would go to rear mount..
cheers john
Project started 16/01/08.
pedro
« Reply #5 on: May 26, 2008, 11:35:31 AM »
I've heard the turning circle is better with the rear mounted too, does anyone make a rear mounted kit.
« Reply #6 on: May 26, 2008, 12:03:53 PM »
Pedro I run a Pat Gardner rear mount and the lock is better than a standard car and lighter with no wondering all over the road as with a steering box CRS also makes a rear mount I think  The front mounted ones I have fitted have all had poor lock ......FC427.....
pedro
« Reply #7 on: May 26, 2008, 12:37:19 PM »
No worries thanks what about sump clearance with the v6, i know it has to be modified a bit but the rack is going to protrude even more.
« Reply #8 on: May 26, 2008, 01:03:00 PM »
Pat Gardner is the V6 conversion MAN he makes kit for all early Holdens and others with a V6 in mind  Google V6 conversions you will find what you want to know on his site ........FC427......
