August 02, 2025, 10:58:59 PM *
Author Topic: Speedo cable  (Read 2951 times)
Gertie
Grey & White rooles
« on: May 22, 2008, 09:21:22 PM »
I recently fitted a new inner cable to my good condition & well cleaned & lubed outer cable.
The speedo worked for a while then ceased to indicate.  I tried a variety of ideas but the one that worked was to insert a short piece of a nail, similar in size to the inner, into the gearbox drive gear, cable entry.
This had the effect of pushing the cable a little further into the speedo drive receptor. Speedo has worked fine ever since.
I assume that the speedo receptor had been worn a bit at the entry popint.
pedro
« Reply #1 on: May 23, 2008, 09:08:15 AM »
Good one, you could say you nailed that problem Roll Eyes Cheesy Grin
julius
« Reply #2 on: May 23, 2008, 10:17:18 AM »
Hi Gertie
I found the same problem with times speedo cable, so I found an original under the house, even though Tim's wasn't broken it must have been an aftermarket on and are shorter i the square bit. Whit old cable in no problems.
But your way of fixing the problem is great.
Julius
