August 25, 2025, 05:49:28 PM *
Author Topic: Etch primer  (Read 4739 times)
GM
« on: April 13, 2008, 11:25:21 AM »
Can etch primer go over body filler where it feathers out to the bare metal, or should i just use a primer?
                      Thanks, Glenn
JSM
« Reply #1 on: April 15, 2008, 02:11:26 PM »
I've done this before and haven't had any hassles with it...yet Grin I don't know of a reason why it can't be.
Prob not much help but by the sounds of it if there's something wrong with it I've got more to worry about than you!! Grin
JSM
On a Mission to fix up my Ute, Five years down so far... hopefully this'll be the last before i can drive her!!!
« Reply #2 on: April 15, 2008, 03:52:36 PM »
Glen are we talking 1k etch or 2k wash primer Huh.....FC427......
NO NAME
« Reply #3 on: April 15, 2008, 07:36:07 PM »
from what ive heard acids in the etch may not be compatible with acids if i use etch i usuallyturn the fan down a bit and just put one coat on the metal and dodge the bog, then i clean the gun, have a smoke and spray on the hs primer.
GM
« Reply #4 on: April 19, 2008, 12:30:07 PM »
Thanks guys, I might try to avoid the filler as much as possible. I`m using acrylic.
                                         Cheers Glenn
« Reply #5 on: April 19, 2008, 06:55:42 PM »
Glen Acrylic is not so bad if you get it on the polyester putty ,just use a rag with thinners on it and wipe over the putty to remove the Etch and then Acrylic prime it ......FC427........
GM
« Reply #6 on: April 20, 2008, 07:32:06 AM »
That sounds good, thanks for the help.
                        Cheers, Glenn
JSM
« Reply #7 on: April 21, 2008, 07:13:13 PM »
What is the result of using etch primer (acrylic) on filler? it hasn't done anything to my paint yet?....
