August 21, 2025, 07:09:07 PM *
Author Topic: Celica 5 Speed onto red 6  (Read 2547 times)
Digger
Classic not Plastic
« on: November 07, 2002, 09:10:43 AM »
G'Day,  Smiley
I have just acquired a 5 speed Celica gear box with a Rod Hadfeild bell housing fitted to it and I need a bit of help,
Could anyone tell me what clutch and pressure plate I need to run and which slave cylinder do I use.
Any help will be appreciated.
Thanks Steve
FC2104
« Reply #1 on: November 07, 2002, 10:32:01 AM »
steve,
The pressure plate you use is a standard holden.
The clutch plate is out of a dyna i think nearly all toyotas use the same size spine shaft so go to were you would buy you clutch parts and get a clutch plate that is the closest to the same diameter as the standard holden
the slave cylinder you use is the standard fc to ek
the bell housing should have came with the mounting bracket
p.s if you still have problems locating a clutch plate give
rod hadfield a ring and ask him for a part number
Dean
Digger
Classic not Plastic
« Reply #2 on: November 07, 2002, 01:27:04 PM »
Dean,
Thank's heaps for the reply,   Cheesy
Now that you have put me on the right track I will get it together and fitted up. (Sick of the trawmatic auto box)
Thanks again,
Steve
