September 09, 2025, 05:37:42 PM *
Author Topic: cOLLASIBLE STEERING COLUMN  (Read 3557 times)
FATBOY
« on: March 21, 2008, 09:35:18 PM »
When do you need one ie what motor size does nsw rego want one  138 149 161 173 179 186 202
Example 138 red motor
 regards fatboy
fatboy
0414712441
« Reply #1 on: March 21, 2008, 09:37:07 PM »
I think when you get to 202 Did you pick up your cars today .......FC427........
FATBOY
« Reply #2 on: March 21, 2008, 09:53:35 PM »
Yeh i got the ute and the vanette today very impressed withe the ute van will be a challenge but im up for it
regards fatboy
fatboy
0414712441
« Reply #3 on: March 21, 2008, 10:45:53 PM »
Hey Fat, I think anything engineering wise depends on the car the engine came from. So if the 179 had collapsable steering then it needs to be in the modified car.
« Reply #4 on: March 21, 2008, 11:40:13 PM »
The rules in Vic are that if you change the column to another model, then the column has to meet current ADR's. That is it must be collapsible and have breakaway mounts. If you leave the original column in place then it can remain stock. This is why V8's need collapsible columns because the column is removed and a rack is installed.
You can run a stock column with a red motor in Vic no problems.
Revhead_Fc
just put a chev in it
« Reply #5 on: March 22, 2008, 09:10:41 AM »
Mark is right in NSW any motor over 186 in an FC FE requires chassis rack and pinion steering and collasible steering unless your lucky enough to find an engineer thatl let thru Wink
Ben
FATBOY
« Reply #6 on: March 22, 2008, 10:55:47 AM »
the ute i bought ek has a 138 red in it so wont have to got to the expense of making a column collasible
regards fatboy
fatboy
0414712441
Spinner
« Reply #7 on: March 22, 2008, 11:24:35 AM »
191.25 CID is the changeover point, according to NSW registration rules.
If you have a 186 + 40 thou, then you're just under at 190 CID.
If you have a 186 + 60thou, bad luck, at 192 cubes you need the collapsible column.
