August 25, 2025, 12:02:13 PM *
Author Topic: BRAKE AND CLUTCH AGAIN ! ! !  (Read 3410 times)
50plus
« on: February 27, 2008, 04:10:16 PM »
O.K took the brake master cyl. off today, sludgy, gooie inside, bit of corosion & slight scoring on the inner wall, l dont know if the contamination of the fluid is from the car sitting around for a couple of years without use &/or topping up with differant types of fluid  l cleaned all the parts up & put it back into use,bleed all 4 wheels ,Now the brake pedal is extremly firm when pushed , way to firm, feels rock hard,  l adjusted the pedal under the dash to give around 1/4inch play but that hasnt helped, So im wondering Which is the correct DOT fluid to use on these old gals?? Could this be the problem?
« Reply #1 on: February 27, 2008, 06:52:46 PM »
Hey 50plus, I reckon the flexible brake hoses have swelled up on the inside and need to be replaced.
ACE  Cool
50plus
« Reply #2 on: February 27, 2008, 08:51:07 PM »
Thanks, that sounds like where i'll be starting in the morning...thanks again....
