July 27, 2025, 10:07:17 PM *
Author Topic: Diff Pinion Angle?  (Read 2839 times)
THOMMO_2
FB-EK Car Club of SA
« on: February 25, 2008, 07:40:07 PM »
Gday All
Is the pinion angle the same on early holdens, FE to HR?
If so, what is the angle?
Jeff
USE IT OR LOSE IT
« Reply #1 on: February 25, 2008, 07:50:32 PM »
 It is suppose to be the same angle as the back of the gear box if you put a straight edge on the back of the box up and down and a straight edge on the rear yolk up  and down the measurement should be the same top and bottom some say it is good to vary the angle a couple of degrees so it doesn't wear the universals in the same spot but up to you  ......FC427.......
THOMMO_2
« Reply #2 on: February 25, 2008, 08:03:34 PM »
Thanks FC427
I did know the why's, I just need an angle on a standard diff.
Thanks anyway Wink
USE IT OR LOSE IT
