August 25, 2025, 10:04:44 AM *
Author Topic: Steering column bracket  (Read 3420 times)
sexyfc
John greco
« on: February 03, 2008, 09:28:39 AM »
Hi guys,
I have a torana steering column and i need the bracket to hold column up and the plate that goes on the fire wall.
thanks
Project started 16/01/08.
« Reply #1 on: February 03, 2008, 01:13:23 PM »
From memory the torana column is a lot thicker than an FC column, so I would say you'd need to make one up.
sexyfc
John greco
« Reply #2 on: February 03, 2008, 07:26:38 PM »
I had a bracket but unsure from where it was from. Lost it in transit.
waynos
patience grasshopper
« Reply #3 on: February 03, 2008, 10:56:32 PM »
got one you can have but is the column about 2 inches(51mm),or more?
sexyfc
John greco
« Reply #4 on: February 04, 2008, 07:21:01 AM »
its 54mm, think it will still fit?
« Reply #5 on: February 04, 2008, 08:34:16 AM »
If you modify the standard (FE FC) top bracket it should work OK.  Shim it up about 5mm under the bolts.
the FE FC toe panel board works too.
waynos
« Reply #6 on: February 04, 2008, 06:25:04 PM »
nothing a die grinder wont fix.do ya want it ?
regarding the bottom bracket its pretty easy to make one
sexyfc
John greco
« Reply #7 on: February 04, 2008, 11:31:52 PM »
Yeah i'll have it, what area you from?
waynos
« Reply #8 on: February 05, 2008, 05:27:57 PM »
i'm at surry hills but the bracket is with my car in nowra,can get for you this weekend
my no. is 0407770223
