August 23, 2025, 08:38:54 PM *
Author Topic: Rear Springs rubber holders  (Read 2218 times)
FATBOY
« on: January 25, 2008, 11:30:23 PM »
Wanted the pieces of metal that hold the rubber insulater that have the u bolt run up each side on the rear leaf springs
regards fatboy
starting the preliminary fit up of the ute before painting
fatboy
0414712441
« Reply #1 on: January 27, 2008, 10:11:54 AM »
Hi Fatboy I don't run them or the rubber insulator I bolt it all together like HQ\WB Ute's Vans and 1Toner's and that lets it all pull up hard and the U bolts don't need to checked periodically as the rubber deteriorates and squashes.Just a thought.......FC427.........
FATBOY
« Reply #2 on: January 27, 2008, 12:20:49 PM »
Thanks for the reply mark
regards fatboy
fatboy
0414712441
Harley
« Reply #3 on: January 27, 2008, 12:51:46 PM »
FC427 I'm not seen HQ\WB Ute's Vans set up but how do they bolt up, do they not use rubbr insulaters,
« Reply #4 on: January 27, 2008, 01:14:24 PM »
Harley the diff sits straight on the spring if you were doing this it would require a bush to locate the diff housing on the centre bolt [I made new saddles when I fitted the Commodore diff with the location hole to suit the centre bolt size ]and then just pull the U bolts up .....FC427........
Page created in 0.083 seconds with 16 queries.
