September 06, 2025, 05:13:50 PM *
Author Topic: SHOW US YOUR BOOSTER  (Read 9597 times)
« on: January 24, 2008, 11:12:25 PM »
Thought it might be a good idea to have all the different types of Brake Boosters we have on our cars that members with this modification in mind can choose from all in one place to make it easy to compare. SO SHOW US YOUR BOOSTER .......FC427.......
« Reply #1 on: January 25, 2008, 09:15:45 AM »
I have an LC/LJ booster and master fitted.
A few firewall mods needed to be made, luckily the booster has a metal spacer so making a template for the new metal on the firewall was easy. I think a clutch master can still be fitted but I haven't tried yet.
I had to cut and reshape a little bit on the inside of the firewall but the original pedal is still used with a custom "adaptor".
NO NAME
« Reply #2 on: January 25, 2008, 10:51:38 PM »
still need to make a inner guard to protect it but it fits in ok and all bolts are accsesable if you take out the front wheel.
« Reply #3 on: January 26, 2008, 11:34:36 PM »
Mark (FC427) sent me some pics to post,  so here they are.
This 1 is a pic of the enginebay of Mark's ute, showing you his booster set up.
« Reply #4 on: January 26, 2008, 11:36:10 PM »
Ooops, doubled up on a pic.
Here's the photo that should have been there.
NO NAME
« Reply #5 on: January 26, 2008, 11:46:22 PM »
man that yellow thing is going to be smick when it hits the street, is it back from the trimmers yet?
« Reply #6 on: January 27, 2008, 09:57:22 AM »
 The yellow Engine bay is one that I have fitted a XA\XB V8 booster mounted hard to the firewall with a small block Chev and it shows that there is ample room with a V8 with Headers. The second is my Daily driver FC Ute with a VB\VC\VH Commodore V8 Booster mounted on the original mount just shortened,both of these use original pedal and as it shows there is no problems with use of a clutch master cylinder and are a easy modification to performer...  Thanks Alex for your help with the post ..........FC427.........
« Reply #7 on: January 29, 2008, 02:15:11 PM »
Top work there Mark.
Here's a pic of my booster set up.
It's an old double diaphragm HK booster.
While not as sleek or sexy as the newer ones, it offers good boost and has plenty of vacuum.  Fit up was a simple mod of the HK bracket and uses HK pushrod.
« Reply #8 on: May 18, 2010, 09:31:59 PM »
Pedro this may help .......FC427.......
Gary C
« Reply #9 on: May 18, 2010, 11:49:24 PM »
Very.very nice.
Gary
« Reply #10 on: May 19, 2010, 06:47:24 AM »
Thanks Mark, the main problem with mine is being a crossflow engine the inlet manifold is in the way but if I can get the booster back far enough it'll have enough clearance, looks like a bigger hole and a shorter bracket will do the trick though.
              Pedro
Page created in 0.117 seconds with 19 queries.
