August 26, 2025, 02:36:13 PM *
Author Topic: fc/fe sub frame  (Read 2710 times)
yogie/mark
« on: October 28, 2002, 10:26:28 AM »
Hi guys and girls
I am in DESPERATE need of a sub frame and front panels for my fc wagon. As i am new to fc's are the fe's and fc's the same as in fc panels and grille sections bolting together.
If so I need one. I'm in Melbourne and I have  ek ute to swap for the bits and peices i need so contact me if you can help me.
call mark on 0411 959 334
« Reply #1 on: October 29, 2002, 12:20:03 AM »
Holes for trim etc differ, but as a general rule every panel is interchangeable between FE and FC.  Subframe is also identical.
doug
« Reply #2 on: October 29, 2002, 10:34:49 AM »
I have a near perfect front subframe. It has zero rust around the front radiator support panel area, all the legs which bolt to the body are original (i.e. not repair sections). There is absolutely no rust except the inner left leg has a very small rust hole, about 1 cm by 0.5 cm on a flat, single thickness section, and another pin hole size one also in an easliy repaired area. It is straight and is already off the car. It has come off a FE wagon
I'm asking $200 and will C.O.D. if you will cover the cost (might cost a bit as I am in Qld)
My email is doug.qld@bigpond.com
Page created in 0.028 seconds with 17 queries.
