August 25, 2025, 08:41:40 PM *
Author Topic: body filler  (Read 2053 times)
GM
« on: December 21, 2007, 07:49:01 PM »
hi guys, after using spray putty, do you need to reundercoat if more body filler is needed?
                         Cheers, Glenn
NO NAME
« Reply #1 on: December 21, 2007, 08:13:49 PM »
do you mean normal plastic filler or polyester filler, you can only use normal plastic car bog on top of bare metal or epoxy primer.
« Reply #2 on: December 21, 2007, 08:20:23 PM »
Hi Glen Do Not put body filler over the spray putty you need to take the primer and the spray putty off ,if you need more filler if I have read this wrong ?? you still need to prime over the spray putty unless you are using 2in one [primer and putty in one ]........FC427........
GM
« Reply #3 on: December 21, 2007, 08:52:15 PM »
Hi, I undercoated, then used Rage gold filler, spray puttied the door (rubbed most back off) but had a couple of low spots. I will just undercoat again and then use spot putty (or filler) ? Thanks
                            Cheers Glenn
Page created in 0.03 seconds with 16 queries.
