June 09, 2025, 12:45:58 PM *
Author Topic: King Pin Seals  (Read 2016 times)
mickusmickus
Brisbane, Queensland
« on: November 30, 2007, 12:31:49 PM »
Hey all,
Just wondering if anyone can help with sourcing the little round disks that sit over the ends of the kingpins, mine got damaged during removal......
What would be the best thing to make them out of it you cant just get newies......I would assume a fairly short metal as they need to be knocked into place fairly solidly........hence be made a mil or two larger than the actual hole they are covering.....
Cheers MT
mickusmickus
« Reply #1 on: November 30, 2007, 12:48:21 PM »
for those of you who are confused I meant SOFT metal not 'short' metal............
FB_MAD
« Reply #2 on: November 30, 2007, 04:07:10 PM »
Funny you should mention it MT as I have the same problem.Both of those "blanks" are missing from the lower kingpin bush/shaft in one of my cars.Grease just comes straight out the bottom when greasing.
I was thinking of contacting a manufacturer of flat washers and see if I could buy the blanks that are left over from punching the hole in the centre of the washer.
Apart from getting one in the size needed for the grease retention in the kingpin ends, it would also be handy to have some in other sizes to use in welding up unused bolt holes, rust holes etc in the car rebuild process.
Anyone know where to buy the blanks from or any other other ideas??
Terry.
Has anybody seen my red pen??
« Reply #3 on: November 30, 2007, 04:21:45 PM »
Pommy cars use this same shape for their welsh plugs Triumph etc. they can be bought in either brass or metal but as for the size you may have to reduce them in diameter if you can't get the size you need. I have one from a king pin set  and it measures at 22.11mm or 870 thou hope this helps......FC427........
« Reply #4 on: November 30, 2007, 04:34:24 PM »
Have just found a smaller one as well Do they use two sizes on the king pins one size for the top and one size for the bottom  HuhHuh The other one is 745 thou or 18.93mm......  FC427........
