July 28, 2025, 02:14:44 PM *
Author Topic: Steering Troubles  (Read 3021 times)
perth_fe_ute
« on: November 05, 2007, 11:31:27 AM »
Hello All,
Thanks for the help so far. Next on my list is the steering and front mounts. I have been driving to and from the garage last weekend on a 48 hour police license as it has not passed the license inspection. I found the steering to be very poor and the car to drift over the road. It has had a hr front end fitted but guess the alignment has not been touched for the last 10 years along with the ball joints etc. Where do I start? can I do it myself? suggested mechanics or shops in Perth, WA?
David.
« Reply #1 on: November 05, 2007, 12:08:06 PM »
It could be any number of things from previous posts on the site, start at the tyres, wheels, then the ball joints, bearings, steering arms, steering gear then steering column.
It could be any one or a combination of some or all.
« Reply #2 on: November 05, 2007, 12:24:30 PM »
The guy doing the inspection will be able to tell you if any of the front end bits are worn or faulty, after all that  is what an Authorised Inspection Station  is being payed for to tell you if your car is road worthy and what needs replacing to make it road worthy and then you have narrowed it down to just a few things  FC427
NO NAME
« Reply #3 on: November 05, 2007, 06:55:18 PM »
if you jack it up and woble the wheels holding the top and bottom is there movement?
if you grab the front and back of the tyre and woble it does it have play?
if it has play does the stub axle look to be moving with the play or staying still?
put the car down of the jack then and see how much play is in the steering wheel when you turn it left and right.
find these things out and someone here could probably tell you what parts need to be replaced or adjusted, most parts arent dear unless you rebuild the whole front end and steering box at once.
also is the car higher or lower than standard?
has it got radial tyres all round?
remember the steering in these will feel different to a 2007 commodore but with the age of them wear is common and a few new bits will change how it steers.
NO NAME
« Reply #4 on: November 05, 2007, 06:57:56 PM »
FC427 is right, the inspection guys should be able to stick it up on a 2 poster or trolley jack and pick it with a quick grab of the wheel and tell you exactly what parts you need to change.
fastjbav6
OK start her up !
« Reply #5 on: November 05, 2007, 08:21:17 PM »
Hey David,
G-Mac in McCoy St Myaree does good steering and suspension work.
Seb
Yellow Knight
