September 06, 2025, 09:16:24 PM *
Author Topic: ignition timing  (Read 3461 times)
fc_mad
in the build
« on: September 08, 2007, 02:24:09 PM »
does anyone know the ignition timing settings for a grey
KFH
« Reply #1 on: September 08, 2007, 06:13:57 PM »
This is a shortened description from the Holden service manual if you do not have a timing light.
1  Make sure points are set between .012 in and .016 in before setting ignition before adjusting timing.
2  Remove distributor cap and turn motor in a forward direction by hand until the rotor is approximately at No 1 terminal on cap and then turn further until the timing mark(ball) on flywheel is over the index mark.  This is the correct position for firing on No 1.
3  Loosen bolt on distributor locking plate and set scale on "zero"
4  Loosen the distributor clamp just sufficiently to allow turning of distributor to be turned.
5  Turn ignition on and remove centre high tension lead and position it so as to form a spark gap.  Make sure the points are closed and turn distributor in an anticlockwise direction until the points "just" open and a spark occurs at the gap.  Tighten distributor clamp screw.
6  Check the timing setting by turning the motor over at least two complete revolutions and make sure a spark occurs when the index mark is over the ignition timing ball on the flywheel when the rotor is under
 No 1 terminal on the distributor.
I hope this is not too confusing.
