July 30, 2025, 11:33:04 PM *
Author Topic: can you shorten the handbrake equaliser  (Read 1764 times)
NO NAME
« on: September 02, 2007, 01:42:19 PM »
i may have a clearance issue with my handbrake equaliser, has anyone done it, this is the flat bar peice that goes between the front cable and rear, do you still get a good hold with the handbrake if you do , is the handbrake much harder to pull.
 i was looking at moving the hole in 1/2" - 3/4"
« Reply #1 on: September 02, 2007, 09:46:11 PM »
Leon, yes you can, but the way to do it is to move the other hole as well. I haven't measured one but let's assume that the first hole is 10 cm from the pivot point and the second hole id 60 cm from the pivot. This means that the ratio between the holes is 6 to 1. If you move the outer hole inwards, then you move the inner hole inwards so that the ratio remains the same. This means that pulling force will remain the same but the travel of the handbrake will be reduced.
Does this make sense?
NO NAME
« Reply #2 on: September 02, 2007, 10:25:34 PM »
makes sense, thanks.
