June 15, 2025, 01:20:36 PM *
Author Topic: Missing chrome  (Read 8604 times)
Walter
Cruising
« on: August 02, 2007, 10:17:31 PM »
Hi i have a  FC Special Station Sedan and on the front guards there two little holes drilled on either side.What sort of badge /chrome belonged there.Anyone know where i can get the bits.I have not been able to find any photos with anything there.
Cheers for any help.
Walter
Cruising
« Reply #1 on: August 02, 2007, 10:31:03 PM »
I dont know if this helps : FC-229-17124-A:
  Vehicle is an FC Special Station Sedan, the 17,124th manufactured in Adelaide, SA
« Reply #2 on: August 02, 2007, 10:34:42 PM »
Hi Walter.
There should be about 5 holes in the side of the guard, more or less in a straight line. A Special Station Sedan has the same stainless trim as FC Sedans on the front guard, a spear about 4' long.
It's not exactly clear where on the guards these holes are that you mention.  However, if they are on the top at the back, it's possible they were for these "Fender Mount" mirrors:
Is that any help?
Walter
Cruising
« Reply #3 on: August 02, 2007, 11:02:23 PM »
Hi,the two holes are under the spear behind the front wheel.
« Reply #4 on: August 02, 2007, 11:06:43 PM »
Walter sent me this pic which I'm sharing in case anyone else knows the answer.  Obviously my brilliant theory about fender mirrors has been blown sky high...
The holes seem too small to be for Buick-style "port-hole" badges, and it would be a strange spot to put them, too.
Does your car have a "dealer stripe" at all, or just the standard FC diagonal flash on the back door and horizontal strips along the side? I ask because I have seen a diecast badge with the name of the Autolux / Tilli's kit the car (or ute, as this one was) had fitted.
Anyone else got any ideas?
Rabbitoh
FE - 'King of Cars'
« Reply #5 on: August 02, 2007, 11:09:08 PM »
tinworm?
Bunnies' 22nd in 2025?
« Reply #6 on: August 02, 2007, 11:15:37 PM »
Unusually neat worms Roll Eyes
Walter
Cruising
« Reply #7 on: August 02, 2007, 11:18:49 PM »
The holes are identical on either side,would they be factory standard holes?
Tin worm lol
« Reply #8 on: August 02, 2007, 11:24:39 PM »
Definitely not factory. There's not even a NASCO accessory that required fitting like that. Only thing I can think of is some sort of badge that a previous owner decided to fit.
Walter
Cruising
« Reply #9 on: August 03, 2007, 12:24:07 AM »
Hi did they make many FC Special Station Sedans ?
TAYZ
« Reply #10 on: August 03, 2007, 07:17:09 AM »
Walter,
               Maybe a previous owner decided his own personal touches.  Every now and then when I have a bit too much of the old amber liquid I go out to the shed and low and behold Ive added something on!!!  On a serious note maybe the previous owner did put his own badges on.  I contemplated for ages whether or not to put some FB stars on my bonnet, I finally gave in and put them on and I think it looks pretty good, next bloke may think otherwise so maybe thats a theory for the holes (not FB stars)
Walter
Cruising
« Reply #11 on: August 03, 2007, 03:31:48 PM »
 8)Alcohol drills and old holdens can be a dangerous mix.I will never forget the day i attacked the bonnet with the drill to put on a hood ornament. I guess i might try a few random special badges and see if they fit the holes and the guards.
« Reply #12 on: August 03, 2007, 08:40:08 PM »
Walter, about 37,170 FC special sedans were made in Adelaide and Melbourne.
Regards Ken
TTV6FC
« Reply #13 on: August 03, 2007, 09:01:49 PM »
Walter,maybe after feeling the power of the Grey,the previous owner decided to attach some "160HP" chrysler badges to the side......yeah ,yeah I know...the time frame is all wrong.....Just thought of it. Grin
HAD 708
« Reply #14 on: August 05, 2007, 04:47:59 PM »
My guess would be a EH type special sript badge which were a very popular retro spruce up look in the 60s and 70s. Also popular to fit too spats etc. The spacing between the holes looks very similar to the badge pins.
Brett
Brett Gillard
